Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
Fs: OK 1990 Crx si with b16
Old Dec 10, 2012 | 05:54 PM
LOV2XLR8 94Z28's Avatar
Default Fs: OK 1990 Crx si with b16
Selling my 1990 Crx-Si with a b16 swap.
SiR swap with full obd1 conversion, socketed p72 ecu with programming from phearable.net
DCSports 4-1 exhaust header
Tsudo n1 style exhaust with custom test pipe
Short Ram intake
Gsr speedo cluter swap
Semi-Solid Motor Mounts
Avid Shift Linkage with dual bend Fidanza short throw shifter and Energy Suspension bushings.
4.4 final drive non-lsd cable transmission
DEI Viper alarm with remote start (door locks have actuators)
14 lbs battery relocation
ACT Clutch
Clean title
Car runs great, the paint is worn do to the fact it's a 22 year old car, wheel bearings are starting to make noise, the ACT clutch does on occasion squeal. Sunroof assembly doesn't quite fit properly, it however does not leak. No A/C but the majority of the components are there, a/c panel has the typical crx cracking, there is no stereo in the car, the speakers and amp wiring will remain. Pictured on SI rims, will come with a set of DelSol rims and tires, and I will also throw in a set of black 16 inch tuner rims that need tires. It will also come with a spare bumper and some other parts i've collected over the years. The front end is a matte plastidip black, this can be peeled off simple enough. The hood however is still black under the plastidip. In the photo the vertical panels on the side are missing, I have them they were being painted when I took the photo they will come with the car.
Pm me if you have any questions, I'm located Oklahoma City/Edmond area.
Asking $2,000 or best offer.
Lucky-13
Jan 6, 2008 08:36 PM
jsull.
Feb 1, 2007 05:47 AM
jsull.
Modified Motors
Oct 21, 2004 10:26 AM
