97 Accord SE coupe +timing belt issue
Old Dec 10, 2012 | 07:38 AM
jordan184mc's Avatar
Default 97 Accord SE coupe +timing belt issue
Removed.
Old Dec 10, 2012 | 11:44 AM
djkurious's Avatar
Default Re: 97 Accord SE coupe +timing belt issue
Originally Posted by jordan184mc
Hello every one I'm new so I hope this post isnt in the wrong spot. I Have a red 97 accord Special edition with 215,000k. she runs perfect, well untill i changed my timing belt. it will start right up and idle just as it did before. it will rev smoothly up untill 2000 rpms at which point it starts to vibrate. anywhere past 2000 rpms it will continue to vibrate (shaking the exhaust and causing a racket) but as soon as it hits 1900 rpms it will run smooth as butter. any opinions welcome.
All timing marks lined up?
Old Dec 10, 2012 | 12:09 PM
arkangel2487's Avatar
Balance shaft timed correctly?
Old Dec 10, 2012 | 06:14 PM
Check it out. You should be able to check it without having to take the valve cover and all that jazzy stuff off. Also check out the thread "timing of balance shafts 96 accord 2.2"
Old Dec 11, 2012 | 03:44 PM
2010coupe's Avatar
Check the balancer gears as mentioned above.....I would make sure you use the recommended screw (6mmx100) if I remember correctly. I used a thinner screwdriver and it through off the timing by about a tooth and a half on the balancer gear.
Did you use a timing light after all was said and done to make sure that it stayed timed at 15 deg. BTDC?
Might want to check that after the car is warmed up
Dfullmer
Jul 13, 2017 08:27 AM
mouab18c1
Jan 13, 2010 01:50 PM
david90
Jun 19, 2004 12:39 PM
d16why
May 31, 2004 02:09 PM
