Transmission & Drivetrain Gearboxes, Differentials, Clutches
Using a Smaller Trans Spline with a bigger Clutch Spline hole
Old Dec 10, 2012 | 06:42 AM
CRXherbie91's Avatar
Default Using a Smaller Trans Spline with a bigger Clutch Spline hole
a little backround: i bought my crx with a b16 swap, with hydraulic transmission, i went from gsr hydraulic to b16 cable, i pulled the gsr trans off, installed the b16 trans WITHOUT changing the clutch... i havent seen what he is claiming yet, so im confused, iwould of put my life on it that i bought the right clutch
since i changed the trans, i had troubles with the clutch when starting from a dead stop..would shift while moving
i pulled the swap, to get that transmission off the motor it took HOURS!!! wen normally it comes right off. well we finally got it off.. he told me the clutch i was running/new clutch spine is too BIG for my transmission i need a new disc..
my question is, what would happen if the trans spline was smaller then the clutch spline? would it even run? ..
Old Dec 10, 2012 | 11:22 AM
Aquafina's Avatar
Default Re: Using a Smaller Trans Spline with a bigger Clutch Spline hole
You either wouldn't go anywhere or would damage the splines then not go anywhere.
Old Dec 10, 2012 | 10:34 PM
Mista Bone's Avatar
D Tranny Guru
hopefully you only ruined the clutch. try sliding on a correct disc to see if it moves smoothly.
Old Dec 11, 2012 | 12:57 PM
94EG8's Avatar
Seagull Management
Also, you need a clutch for a '90 - '91 Integra.
MichealSenior
Feb 17, 2009 12:56 AM
DA6Iceman
Sep 13, 2005 06:48 PM
quik89
Sep 15, 2004 06:21 PM
The Real Funk
Dec 19, 2002 09:47 PM
