Check this valve spring compressor out...asking for opinions
Have any of you seen/used this valve spring compressor? Seems to be the best value, but is it a practical and good tool to get as opposed to the eurosport or other compressor? thoughts,ideas, suggestions
http://www.ebay.com/itm/V-TEC-Honda-...5f85e5&vxp=mtr
I am assuming you mean the handheld one and not the one that bolts up to the outter cam cap holes. Ive done a little digging and while videos seem like its a good choice, people argue on the forum that with aftermarket springs it is difficult using the tool and that it can even potentially strip keepers/valves
Ask the general public that have actually used the hand held. I personally use it and it makes the spring retainer swap an hour or less ordeal
Thanks for the feedback. Majority rule definitely lies in one of these handheld spring compressors: snap-on, blue point, valve master, etc.
hand held one. I've done aftermarket valve springs all the time. One of the best time saving tools I have. I own the snap on one also that bolts to the cam caps, but after using the hand held, its a no brainer.
i use the valve master worked great so far done about 4 engines with it.
http://www.toyotool.com/
as far as using it with aftermarket springs i dont know
it didnt take much effort at all to remove the ITR springs from one head and put them into other
putting them in took me about 5 minutes total
JDM_SOHC
Mar 23, 2012 01:42 PM
Fezzie
12
Aug 21, 2006 12:49 PM
