Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
shifter problem
Old Dec 9, 2012 | 03:48 PM
chawski's Avatar
Default shifter problem
Over the past month or so I have started to notice some changes in shifts. when going from 2->3, the shifter gets very firm and almost difficult to get into 3rd once it gets past neutral. If going from neutral to 3rd, its fine, but when i go from 2nd to 3rd, it gets stiff past neutral.
I pulled out the console to see if there was anything obviously weird going on and nothing was jumping out at me as broken or worn appearing
Any idea at all? is there anything that can be lubricated maybe?
Old Dec 9, 2012 | 07:45 PM
toyomatt84's Avatar
Sanji
Default Re: shifter problem
Have you replaced the transmission fluid ever?
Old Dec 11, 2012 | 11:22 AM
chawski's Avatar
yes, but its definitely old. what do you recommend for tranny fluid for a 01 MT?
Old Dec 11, 2012 | 04:17 PM
AccordEX1991's Avatar
Is it a 5 speed manual?
If it is a MT, bleed the clutch first. It sound clutchs like the clutch is not disengaging or releasing making it hard to shift.
Old Dec 12, 2012 | 03:42 PM
toyomatt84's Avatar
Sanji
Honda MTF. Its far superior then what's available through local retailers.
Old Dec 13, 2012 | 03:39 PM
chawski's Avatar
I had orig thought that as well, but there is no problem going from any gears except 2 to 3. yes it is 5MT. Either way, im gonna bleed the clutch and do a fluid swap this weekend. If i need more hydraulic fluid, is there any specific brand I should go with?
Old Dec 13, 2012 | 04:37 PM
toyomatt84's Avatar
Sanji
Honda Brake fluid. Its the same stuff they used in your clutch line.
Old Dec 14, 2012 | 08:49 AM
chawski's Avatar
sweet, thanks for all your help! hopefully ill be able to report back this weekend
Old Dec 14, 2012 | 01:44 PM
cb450sc's Avatar
My son's '93 Civic had the same problem going from second to third. I first changed the clutch fluid, then did three drain and fills of the transmission about a week apart. It has been fine for the past two years.
Old Dec 15, 2012 | 11:11 AM
chawski's Avatar
good to hear! weather isnt looking like its gonna let me do much today, hopefully tomorrow!
Old Dec 16, 2012 | 10:29 AM
oarce05's Avatar
I'm having a similar issue but I just changed my tranny fluid. Can I still bleed the clutch without having to mess with the tranny fluid?
Old Dec 16, 2012 | 01:32 PM
toyomatt84's Avatar
Sanji
Yes. They're two separate systems. Clutch line hydraulic fluid never actually enters the transmission housing.
Old Dec 16, 2012 | 01:43 PM
oarce05's Avatar
Awesome. Thank you sir.
Old Dec 23, 2012 | 01:05 PM
chawski's Avatar
just did the tranny fluid and it shifts like new. Looks like i got to it before anything sht the bed on me! thanks toyomatt!
b20bFourDoorCivicLX
Apr 8, 2012 01:06 PM
sean2000gt
Dec 15, 2008 08:59 PM
spintboy
Feb 1, 2008 09:01 AM
B18c5__Owns
Apr 3, 2006 10:28 PM
