H22a Idle fluctuation - VIDEO - help me pinpoint!
Hey guys, I'll try to keep this brief and to the point:
I have a 90 Civic with an H22a using a stock P13, and idle issues after warmup.
Youtube vid of warmup process and aftermath: http://youtu.be/hecnUg8AMuk - Jump to 4:15 if you're impatient or have seen a Honda or two get to it's warm idle.
Coolant is bubble-free.
Runs great, but I can't be bothered to constantly smooth out the idle with my right foot at every clutch-in to actually drive this beast/turd around... TIA
Did you ever fix your idle issue? I just had the same deal on my 92 lude w/ 2.3. I was a dumbass and first things first i replaced the IACV which all of the forums said it was. Wrong. I removed my throttle body and adjusted and cleaned the FITV. I dont know the exact specs but from looking at prior threads and turned the white plunger all the way in (clockwise) until it stopped and backed it out 1 and 3/4 turns (counter-clockwise) and that fixed my issue. I wasted 170.00 on a new IACV when all i had to do was adjust the FITV. Good Luck.
Check out this thread from the FAQ, it covers virtually everything that
can cause idle probs and how to fix them,
https://honda-tech.com/forums/honda-prelude-4/end-all-idle-surge-bounce-etc-problems-thread-1979500/
, removes this possibility from the equation?Check out this thread from the FAQ, it covers virtually everything that
https://honda-tech.com/forums/showthread.php?t=1979500
