Honda CR-V & Element 2WD & 4WD Element & CR-V
01 4wd Trans work in a 98?
Old Dec 8, 2012 | 06:30 PM
Christianva's Avatar
Default 01 4wd Trans work in a 98?
will a 01 4wd Trans work in a 98 CRV? does anyone know?
Old Dec 8, 2012 | 08:24 PM
NZ-DB8R's Avatar
Default Re: 01 4wd Trans work in a 98?
If they are both RD1 CR-V with B20 engine then yes
Old Dec 9, 2012 | 01:14 AM
boliviansol's Avatar
Yes
Old Dec 10, 2012 | 07:17 AM
thanks for the help! makes my search more easier!
Old Dec 10, 2012 | 08:26 AM
jay_see_eye's Avatar
if its manual yes auto no because no overdrive int the earlier models
Old Dec 11, 2012 | 06:53 AM
well reading the service manual electronically its the same. the 97-98 has a position for it while 99-00 has a button. they both use the same wiring to the pcm but im not sure about the gear selector in the transmission yet for hydraulic purposes.
Old Dec 11, 2012 | 07:40 AM
just looked at part numbers for valve bodies. for 97-98 and 99-01. Valve bodies are different. so damn i do not think they are interchangable.
Old Dec 11, 2012 | 09:53 AM
It will work. Do u know someone thats sellin an 01' cheap?
Old Dec 11, 2012 | 02:15 PM
so how would you know that it will work? is it base on personal experience or just hear say? im planning to buy a rebuilt one or go used with low miles thats why im inquiring if 99-01 tranny will work on a 98. its just 97-98 has an extra position on the gear selector which may interfere with the 99-01 valve body. i would like some legitimate facts rather than going on someones opinion. right now by me skimming through the service manual valve bodies are slightly different due to the manual valve selector.
kelviiv
Oct 18, 2013 06:11 PM
BIGDOGLC
Transmission & Drivetrain
Aug 15, 2010 04:22 PM
5_Lug_B
Jul 25, 2007 06:21 AM
anomale
Feb 5, 2005 11:05 PM
4DRPIMPIN
Honda Motorcycles
May 31, 2003 05:36 AM
