NEED HELP: RPM IS BOUNCING AROUND WHILE DRIVING AND IN PARK 95 INTEGRA B20VTEC
Ok guys and girls, my RPM is bouncing around while driving and loses all power and sometimes backfire. Even i am parked, it still bounce around. What can cause this problem?
Tach output is from the ICM, [in the distributor assembly] a bouncing or no tach is an indication of a bad, [or going bad] ICM...
http://easyautodiagnostics.com/honda..._systems_1.php 94
What do you mean, "won't even crank"?
Is the starter motor not working?
I would start by checking the batt. voltage, [should be 12.5V] then redo the main grounds, [batt. post and cable clamp, batt. to chassis ground and chassis to engine ground] DO NOT just eyeball them, disconnect/clean/reconnect.
If still no crank...
https://honda-tech.com/forums/showth...cm+bypass+jump 94
