Lighting HID/Xenon kits, Retrofits and Associated Topics
Instrument Cluster, Dome Light, License Plate LED Bulb Sizes
Old Dec 6, 2012 | 06:36 PM
seantobin5's Avatar
Default Instrument Cluster, Dome Light, License Plate LED Bulb Sizes
Hello there, I've been doing some research and I cannot come across a straight answer. I have a 1998 Honda Civic HX (has a tachometer, manual transmission) I'm looking to replace the instrument cluster light bulbs with LED's from superbrightleds.com. I don't want anything too bright that will cause hot spots and/or cold spots. Just something that makes it so when I'm driving at night I can see the numbers easier as it is very dim now being the original bulbs that came with the car back in '98. I was hoping I could get a list of what size bulbs I need and how many of each I need. I was also wondering what size bulbs I need for the two light bulbs on the top of the cluster.
Also, I was hoping to change out the dome light bulb and was wondering what type of connector it is? It is the DX/CX/HX Dome light so it only has a connector on one side, not the bulbs with the connector on both sides and the bulb in between if you know what I mean. I was also wondering what size bulbs I could use for the two license plate lights?
Thank you very much for reading and your time and have a great evening!
Old Dec 7, 2012 | 05:10 AM
KanjoStyleEg's Avatar
Default Re: Instrument Cluster, Dome Light, License Plate LED Bulb Sizes
Idk if this will help, but I just installed one of the universal LED dome light plates in my Eg. It comes with a few different adapters to fit in the factory spot. I got the 24 smd led plate off ebay for like 3 bucks and it works great, bright as hell. Hope it helps, my next task is the tag and cluster lights as well.
kennykenny
Jul 31, 2015 09:57 AM
shermanyang
Honda CR-V & Element
Feb 12, 2013 03:02 PM
mortificationrock
Dec 10, 2008 10:51 AM
slammedda9
Jun 10, 2008 09:07 PM
jdm206
May 8, 2007 09:07 PM
