Need help with CEL troubleshoot CODES 43/45
Old Dec 5, 2012 | 03:44 PM
jdmhondas4life's Avatar
Default Need help with CEL troubleshoot CODES 43/45
hi every one thanx for ur time i am having problems trying to fix the CELs my car is throwing i have a 00 em1 with a stock b16 i do want to mention that i have a kill switch and i deleted the cruise control system...... at first the CEL would turn on and of at random times so i replaced my MAP sensor and it kinda worked for a while but now its solid and won't turn off i changed fuel filter and treated my fuel with injector cleaners to see if it would do but it didn't it was running good but my gas milage dropped and also a little performance dropped but now my car jerks wen I'm about to take off or wen I'm in low rpms I've read on these code and found out that it can be a vacuum leak, exhaust leak, or bad fuel pump haven't really checked the fuel pressure yet but i was looking for some feed back from you guys see if u can guide me a little to solve this issue thanks again!!.
Old Dec 5, 2012 | 04:25 PM
moejoepotatoe's Avatar
Default Re: Need help with CEL troubleshoot CODES 43/45
First thing you want to do is find out what the codes are then you can go from there. No one will help you if you're not giving importat details like obd1 or 2. Find out those codes and go from there, I'm new to the imports but its super fun learning new things.
Old Dec 5, 2012 | 05:39 PM
First.EG's Avatar
It more then likely gonna be your o2 sensor/s.
Old Dec 6, 2012 | 05:46 AM
jayrdee's Avatar
just as moejoepotatoe said, get the codes and go from there. the CEL is on for a reason so once you figure out why, you can fix it.
Old Dec 6, 2012 | 01:19 PM
First.EG's Avatar
Can you guys not read the TITLE.
Old Dec 6, 2012 | 04:53 PM
For moejoepotatoe and jayrdee my car is a 2000 em1(civic si) any car from 1996 and up in the U.S is going to be OBD2 (unless swapped) and either way all the codes are the same for OBD1 and OBD2 i thought most people here would know by know what those codes are #43 fuel system, #45 fuel system rich or lean. which are very broad problems many things can be causing these codes to turn on CEL. and for First.EG im also pretty sure that if it was the O2 sensor i would get code #2 wouldn't I ?. i did more research and found a thread that it can possibly be valve adjusting.... dose any one have more input on this ???
Old Dec 6, 2012 | 08:04 PM
First.EG's Avatar
You wouldn't get code 2 necessarily as the o2 is part of the fuel system.
Remember that the o2 controls the fuel mixture which can cause rich and lean
Conditions. See if a friend is willing to let you borrow his o2 sensors.
Old Dec 7, 2012 | 07:53 AM
Hey First.EG thanx for the info im going to try it out this weekend hope it works oH yeah and should i change both primary and secondary oxygen sensors? or just the primary?
Old Dec 7, 2012 | 08:50 AM
Spunkster's Avatar
Did you follow the Helms troubleshooting steps for those codes?
Old Dec 7, 2012 | 01:38 PM
First.EG's Avatar
No problem man. If its been along time since you changed anyone of them
I would just change both. Them me know how it goes.
Old Dec 8, 2012 | 06:27 PM
No Spunkster i couldn't find it i am going to keep looking for it to read more on this problem.
Old Dec 9, 2012 | 05:35 AM
spAdam's Avatar
Loved
Community Favorite
Start with reading the Helm manual. The troubleshooting flowcharts are great and the books can be downloaded.
Old Dec 11, 2012 | 03:24 PM
hey wats up every one sorry for taking long to reply...well this weekend i was planning to replace the o2 sensor and wen i opened my hook this is wat i saw...... oil leaking between block and head only on the exhaust side of the motor also my coolant was low and i had oil in the spark plugs of cylinder 1 and 2 (more on 1 though) i did want to mention that the last time i changed my spark plugs the one broke off (on cylinder 1) and i used a bit to extract the part that got stuck in one occasion i also saw that there was fluids coming out of my exhaust and one day but though it was rain water from the night before... now im believing that i had a blown head gasket and im getting these codes because cylinder 1 is misfiring due to all the oil in the spark plug what do you guys think ???? (click on images to enlarge)
Old Dec 11, 2012 | 05:01 PM
First.EG's Avatar
I can't tell on that last pic but if there's oil in the radiator you got bigger problems then your o2 sensors. And oil on your plugs isnt helping it change those o rings on the valve cover.
Old Dec 11, 2012 | 06:59 PM
no there was no oil in the radiator i was just showing how much coolant i have lost was i was more concerned of is the head gasket being blown and the head cracked by the spark plug thread in cylinder one
Old Dec 28, 2012 | 06:03 PM
i know this post is probably dead already but for any one that might use this information here it is...... it wans't my head gasket that was blown or the 02 censors that were giving me problems it ended up being a bad distributor coil one spark plug wire and the leak in the pictures was from the cam seal and vtec solenoid.... i first found out of the spark plug wire by removing it wen car was running it turned out that sparks were weak and they werent reaching the spark plug... so i got the wires all of them new but the spark was weak so i took the coil of and took it to get tested and yup it was bad so i got a new one then i just gave my car a good ignition timing to make sure it was good and that did the trick... as for the leaks i got a new valve cover gasket kit, cam seal, and vtec solenoid seal... and it stopped leaking
BallinDA256
11
Aug 15, 2011 07:47 PM
19cIvIc94
Mar 2, 2009 12:03 AM
zippo1130
Jan 16, 2008 04:40 PM
str8JDMteggy
Jan 28, 2007 11:23 PM
nate10498
Apr 10, 2006 08:54 AM
