Knocking sound, LCA bushings???
Old Dec 5, 2012 | 11:21 AM
06mmDc5's Avatar
Default Knocking sound, LCA bushings???
So I have had this knocking sound in my car for awhile. I have had it since I installed eibach sportlines. I have since upgraded to coilovers in July and the noise is still there which obviously leads me to believe it is not the coilovers. I had thought it might be the coilovers for the longest time till today when I looked again, my LCA bushings we pretty bad. They were torn.
So could the LCA's be the culprit of this knocking noise??
Old Dec 5, 2012 | 11:32 AM
R0FLK0PTR's Avatar
Default Re: Knocking sound, LCA bushings???
check for wheel hub play, determine what is loose. as far as your bushings go. theyre worn out too. replace them.
Old Dec 6, 2012 | 06:52 AM
06mmDc5's Avatar
Alright thanks.
Any other inputs on this?
Old Dec 6, 2012 | 09:46 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
If you can physically see a bad worn or torn LCA bushing that could definitely be your clunking or noise. Pull it off, press in a new one and find out for sure.
Maireeka
May 18, 2006 08:33 AM
alwaysoverkill
Suspension & Brakes
Mar 21, 2006 10:44 AM
chewabacha
Mar 11, 2004 09:52 AM
b18c5ivic
Mar 29, 2002 06:12 PM
