1995 Accord LX engine fan stays on
Old Dec 5, 2012 | 06:17 AM
maverickrob's Avatar
Icon2 1995 Accord LX engine fan stays on
My 1995 Accord LX (4cyl) engine fan will stay on or come on 5 to 15 seconds after I turn engine off. It will shut off after about 30 or 60 seconds depending on how warm it is. Is this normal for that model and year?
Thanks.
Old Dec 5, 2012 | 09:53 AM
jabontke's Avatar
Default Re: 1995 Accord LX engine fan stays on
Mine does it, and it's not a problem for me.
Old Dec 8, 2012 | 11:01 AM
Lost Again's Avatar
This time of year in north america....I find it strange. I'd check the coolant level
Old Dec 10, 2012 | 05:24 PM
Quence's Avatar
Normal. somehow the system tries to keep the water below a certain temperature.
Old Dec 11, 2012 | 03:09 PM
Lost Again's Avatar
I fully understand how the cooling fans work on these.....Just this time of the year if thermo b is seeing temps of ~223.....I would be worried. Especially you "jabontke", I know exactly the temps where you live......when was the last time you used an IFR Temp reader and actually measured the temps of your car? Harbor Freight on Capitol/US1 just north of the beltline had them on sale for $20 not that long ago.
If this was July in NA then that is a different conversation
This describes the 4th gens....but the 5th are only slightly different.
https://honda-tech.com/forums/showth...ht=cooling+fan
Old Dec 13, 2012 | 10:48 AM
jabontke's Avatar
When I cut my car off, the fan will turn on about 3 minutes later and then shut off at some point after that. My guess is when the thermostat gets hot enough from sitting, it grounds the fan relay (which apparently still have power in the circuit in my car) and the fans turn on. They shut off eventually and don't stay on ling enough to cause a battery drain in my car. My car is not too hot, I know my temp gauge works fine.
dblack
Dec 19, 2023 04:53 PM
accord4
Jan 21, 2010 05:04 AM
toyonda
Jan 26, 2009 06:06 AM
david90
Aug 16, 2004 06:41 AM
mooreja90
Mar 9, 2004 05:16 AM
