Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2012 Accord-Coolant Smell
Old Dec 5, 2012 | 06:12 AM
jaimee8463's Avatar
Default 2012 Accord-Coolant Smell
Anyone having an issue with a coolant smell from inside the car that comes and goes when the heat is on. Doesn't appear to be loosing coolant in res.
Drove me crazy. Had dash out of car and still can't find any signs of coolant leak at heater core etc. Anyone???
Old Dec 5, 2012 | 08:09 AM
bgdriver's Avatar
Default Re: 2012 Accord-Coolant Smell
It's a 2012. Just take it to the dealership and have them check it out under warranty. If it has more than a few thousand miles maybe replace the cabin filter.
Old Dec 6, 2012 | 12:57 AM
swordofdoom's Avatar
I haven't noticed anything similar to that, but it might be your cabin filter. I would suggest you to drive with the heater on at MAX and re-circulation ON and have the windows open to flush out any bad smells. Usually helps since I smoke in my car....
Old Dec 11, 2012 | 06:25 PM
bike1962's Avatar
I have the exact same smell on my 2012 4 cylinder. It happened the day I bought the car. Dealer said it was a "coating" on the heater core that had to burn off. 1500 miles later its still happening. I thought @ first it was the new all weather mats I installed? Something is definitely up with it. It seems to be not as strong if I have it on recirculate? It also takes forever to reach the normal temperature range and it takes a long time to heat up. Brand new car? My 2001 CRV heats up faster than the 2012 Accord?
Old Mar 28, 2013 | 09:44 AM
jason67's Avatar
Has anyone found a solution to this problem yet? I have a 2012 that I just bought a few months ago and cannot figure it out. Dealership has been over and over the car but no reason for the smell.
I guess it's worth clarifying that I work at the dealership. We have been over the car in detail several times. If we could find the issue it would be fixed. I have sold many of these and driven them as my own personal cars since 2008 when they redesigned it. I have never had anyone come back with this problem or experienced it in any other car. There is few other instances of people posting this and they all are 2012's only. I was just hoping some that posted this found the problem and fix. We can replicate it easily since its everytime the car warms up. We just can't find where it's coming from. No leaks. System holds pressure. If its losing any coolant it's so minimal that is hard to measure because of normal temp variances.
Old Mar 29, 2013 | 08:52 PM
Possibly a leaking Heater Core
Old Apr 9, 2013 | 09:08 PM
djblinx89's Avatar
Has anyone replaced the cabin filter? If so, did it stop or stop shortly and come back?
Old Apr 11, 2013 | 08:23 PM
ILOVEGIRLS's Avatar
i know its a long shot but when i had that problem it was the head gasket.
Ethylment
Honda CR-V & Element
Jan 20, 2013 07:59 PM
tweee
Feb 5, 2008 11:37 PM
verbal assassins
Feb 12, 2007 10:42 PM
jvonb
Jan 10, 2006 03:30 AM
dunkd
Nov 13, 2003 07:28 AM
