start of the poor mans type r swap
Old Dec 4, 2012 | 05:34 PM
asianpoet's Avatar
Default start of the poor mans type r swap
Heres a pic of the rear, the front is still a working progress. Im still waiting for my bearing to come in
Heres what just came in.. rear prelude hubs, with type r rotors
Modifying the nut. cutting the top portion off, as it doesnt make contact. then drilling holes.
also picture not shown is the hole drilled so that a cotter pin, on in this case. Tie Wire
if its good enough to keep bolts from comming loose from airplanes, motorcycles. Im sure its good enough for my car.
difference of the caliper bracket
Heres what the finished product
Searching over the net, and H-T this is where my info came from:
https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/
within that culmanation of info, and other jargon. it states to tack weld a the nut. but doing it this way makes it easier to remove if needed.
JMac Dc2
Suspension & Brakes
Feb 23, 2011 11:34 AM
CustomEJ6
May 31, 2007 12:20 PM
huge230
Feb 22, 2007 04:31 AM
SOHC_me
Feb 8, 2007 11:54 AM
corylahey
Dec 18, 2006 06:19 PM
