Need 2000 Accord Guru Help!
Old Dec 4, 2012 | 07:20 AM
Blckcivic01's Avatar
Icon3 Need 2000 Accord Guru Help!
Hello everyone,
I love this website because you all are so great in helping me with my wifes 2000 accord v6. Last month we had the main fuel pump relay replaced on it because it would start up and then shut right off. it has been running just perfectly up until last night. We went into wal mart got some groceries and came back out within id say maybe 45 mins. When i got in and started it up it started and then cut off again. when i started it back up and second time it stayed on. but this time when i reved it up it was almost as if to say had somehting clogged in its throat. it would rev up but have almost like a shutter to it while reving. and when i let off it just would cut out. could this be the relay going bad again? or maybe something different? the car is a 2000 v6 with about 135k on it. once again i live it to you experts. thanks for any help you can provide me once again.
p.s. the shop i took it to says there is nothing wrong. go figure.
Old Dec 4, 2012 | 09:10 AM
jdowen2's Avatar
Default Re: Need 2000 Accord Guru Help!
Doubt if it's the relay, it would either run or not. Possibly fuel pump or fuel filter.
Old Dec 4, 2012 | 05:28 PM
Eck's Avatar
Eck
It's not the fuel relay -- it's a common problem on 2000 Accord V6s caused by fuel vaporizing in the fuel lines, which occurs under certain conditions:
1. The car has warmed up to its normal operating temperature
2. The car is turned off and sits for between 15 and 45 minutes.
3. Winter blend fuel is used in the car (causes the issue more often, but not necessarily required)
You can prevent it by avoiding the 15 to 45 minute window mentioned above. Otherwise, you can either wait it out or keep the revs high and non-vaporized fuel will eventually get to the engine. The permanent fix is a modified fuel pressure regulator and a new ECM, which costs ~$800 and generally isn't worth it.
Google fuel vaporization Accord 2000 V6 for more information. Also, here is the Honda service bulletin addressing the issue: http://ww2.justanswer.com/uploads/ac..._heat_soak.pdf
Old Dec 4, 2012 | 07:29 PM
jdowen2's Avatar
What codes are you getting? Do you live in one of the states listed on the service bulletin?
Old Dec 5, 2012 | 01:33 PM
Eck's Avatar
Eck
Note that I, along with many others, don't live in the states listed and still have the issue.
Old Dec 5, 2012 | 03:50 PM
jdowen2's Avatar
What codes are stored?
Old Dec 5, 2012 | 06:51 PM
Eck's Avatar
Eck
It doesn't always trigger a code, but when it does I get random cylinder misfire.
KeenanTurnure
Sep 1, 2015 02:59 PM
newtpa
Oct 21, 2012 06:22 PM
TheGop
Feb 22, 2009 03:53 PM
Trevor
Jan 28, 2007 02:16 AM
