96 h23 to f22b help!! SENSOR HELP??
Hey everyone I have a 96' prelude i pulled the h23a3 JDM motor out and bought a JDM f22b dohc, iv switched over everything including the intake manifold, power steering brackets, engine mounts, ac compressor, so everything is switched over but the h23a3 has two sensors on the front on the block (i believe its the crank position sensor??) i habe to use the h23 wire harness and the f22 block doesnt have a place for the two sensors. So is there a way i can use the external coil distributor off the h23 and wire the crank sensor to it or anything? iv searched and searched and cant find anything.. id really appriciate ANY help. thanks!
Brent,
Brent,
go to rywire and see if they can make a conversion harness for you to run your ckp from the distributor.. comming from a 5 gen, i bought one to move the sensors signals from the distributor
