EK coupe built lsvtec
Old Dec 2, 2012 | 11:37 AM
18k's Avatar
18k
Default EK coupe built lsvtec
Located in Michigan.
2000 civic ex
183k on the cluster, goes up as I daily this
Driver door handle broke
This car doesn't leak nor burn anything.
absolutely not a spot if rust. Underbody is cleannn.
needs tlc, interior has seen its better days. Previous owner spray painted the body white. I replaced the front end to a cleaner one, but hood doesn't align too well.
New spark plugs and wires.
New alternator
Lsvtec running on a stock p28
b16 head
-Ctr cams
-JG dynamic racing cam gears
b18a1 block
-JE 11:5:1 forged pistons
-ls rods
-arp head studs
-arp rod bolts
Exhaust & muffler brand new, done by a local shop.
DC header
innovative mounts
skunkworks springs, kyb struts
Si rear disc brake conversion
drilled/slotted rotors all around
passwordjdm rear bumper straps=tytejdmyoo
aftermarket Lca's and rear camber
SI wheels with 2 new tires, 2 75% tread
Carbonfiber trunk lid.
Blox purple extended lug nuts
$3000 FIRM!
Old Dec 2, 2012 | 11:41 AM
18k's Avatar
18k
Default Re: EK coupe lsvtec
boosted.si04
Oct 13, 2015 08:39 AM
shivic
Nov 20, 2010 12:43 AM
MikeY326
Feb 2, 2010 09:17 PM
fast4imports
Aug 18, 2007 08:11 PM
skyliner186
Sep 20, 2006 02:22 PM
