ef ls problem
Old Dec 1, 2012 | 06:50 PM
motoman32002's Avatar
Default ef ls problem
Ok did a ls swap in a dpfi 88 shell converted to mpfi hooked everything up and it will not run it fires then shuts down with a pm6 obd0 ecu however if I put a pm5 ecu in it it runs but not well please help also getting a code 8 I know the dizzy is good
...another thing is with the pm6 the injectors shoot one burst of gas
Old Dec 1, 2012 | 07:29 PM
Default Re: ef ls problem
Also ecu is obd0 and I repinned the dizzy connector to obd1
Old Dec 1, 2012 | 07:31 PM
Dioxine's Avatar
I would double check the repin job you did on the dizzy for starters, your problem will lay somewhere in the wiring
Old Dec 2, 2012 | 05:40 PM
TKATS_EF's Avatar
I bet if you used a obd0 PR4 ecu it would probably run just fine. Both ecu's youre using are having a hard time figuring out the b18 distributor signals. the pickup gears inside the b18 distributor differ from that of a sohc mpfi and dpfi. try and borrow a PR4 ecu and see if it cure your problem. also better to use an obd0 distributor with obd0 ecu. Hope this helps you.
Old Dec 7, 2012 | 07:41 PM
hatchdan's Avatar
I have a D16Y7 ef and smokes a lot. I think the sensor detects no map that I connect and disconnect and nothing happens
Old Dec 7, 2012 | 07:43 PM
hatchdan's Avatar
also the distributor is conected wire to wire
where should I start?
JuneBugDrfter
Aug 8, 2013 12:39 PM
morganm58
Oct 1, 2011 01:53 AM
thirteen20CRXSi
Nov 15, 2008 08:25 AM
turbo_d
14
Jul 8, 2008 04:38 PM
89hatcher
Jun 5, 2006 02:01 AM
