Daytime running lights, gauge cluster lights, and running brake lights>>not working
Old Dec 1, 2012 | 02:14 PM
kingh90's Avatar
Default Daytime running lights, gauge cluster lights, and running brake lights>>not working
my daytime lights ( side markers....ect) and guage cluster lights, running tail lights are not functioning ( break lights work when break is applied). the lights were working all day until i purchased a Cobra Radar Detector. when i plugged it into the ac/dc port. everything was working fine... i went to the gas station to get gas, turned car off, got gas and when i started the car is when the problem erupted can anyone help. i just got done getting new fuses installed from pep boys. still not working...anyone ??
Old Dec 1, 2012 | 02:34 PM
Swap'DShuttle's Avatar
Default Re: Daytime running lights, gauge cluster lights, and running brake lights>>not worki
Fuses pop when there is a fault in the circuit. Like a wire thats insulation has worn off and is grounding or shorting to metal for example. Find the fault, the fuse will stop blowing.
Old Dec 1, 2012 | 04:25 PM
nemesis25's Avatar
Check for loose connector(s) going to the fuse box under the dash. More specifically, the one that goes from the light switch to the fuse box.
Old Dec 1, 2012 | 05:15 PM
bigblue7t6's Avatar
I would also look into a faulty ground connection, maybe look into the wiring schematics and see if some of those circuits have a common ground
Old Dec 1, 2012 | 05:50 PM
Also check if the fuse is blown again or not.
Jamie Martin
Jan 14, 2013 07:17 AM
xkellyxveitx
Nov 7, 2010 08:44 PM
jobe_149
Feb 11, 2005 08:31 PM
SlowDC4
Jan 1, 2005 06:59 AM
shaferz
Feb 29, 2004 07:19 PM
