honda civic type r ep3 running bad. Help.
It sounds like your engine is misfiring, and your check engine light is on. The first thing you should do, is retrieve the DTC's(diagnostic trouble codes) from the engines computer. How many miles does the engine have on it, it may be past due for a major tune up, Valve adjustment, spark plugs, air filter. If you have any cheap parts, distributor cap & rotor, plugs wires, swap these out for some good quality OEM parts.
Marcin Rollak
Honda Civic (2006 - 2015)
Apr 2, 2019 12:30 PM
hondacivic97si
Nov 7, 2013 11:17 AM
Psychoguitarz
Oct 27, 2012 04:23 AM
