Trouble removing key (2002 Accord V6)
Old Nov 30, 2012 | 07:32 PM
cavaliertx's Avatar
Default Trouble removing key (2002 Accord V6)
Interestingly...i just posted my first post recently. I took my car in and it had a oil leak from the main rear oil seal. The car was left w/ my parents in another city. My dad picked it up this Tuesday and he said he has problems removing the key when he turns off the car. Sometimes he turns the car back on and moves the shift to different gears to reverse, neutral, etc. and then back to park. Then he is usually able to remove the key.
They said we need a new shift assembly unit. I suspect that they screwed something up when they were repairing main oil seal. I spoke with my friend's dad. He thinks they didn't adjust a cable correctly when they put transmission back in after they had repaired the rear main seal.
thoughts?
Old Dec 1, 2012 | 08:30 AM
Lost Again's Avatar
Default Re: Trouble removing key (2002 Accord V6)
I have to agree with your friends dad....something with the shoft cable is not right. To get to the rear main the trans had to be moved and so the cable had to be removed. Did they get the proper adjustment.......or forget about it and damaged it while doing the work.
Old Dec 1, 2012 | 05:28 PM
jdowen2's Avatar
per FSM the A/T shift cable needs adjustment or faulty key interlock solenoid/switch.
blackZC (W)
Nov 12, 2019 03:05 PM
RA21625
Transmission & Drivetrain
Apr 1, 2015 03:47 AM
all_motor_mike
Jan 23, 2013 06:08 PM
japcarmad
Jun 25, 2012 09:48 AM
