wiring iabs
Old Nov 30, 2012 | 11:58 AM
prelude2.2vtec's Avatar
Default wiring iabs
so i did a previous thread on what i observed w/how the iabs worked. well today i ghetto rigged what looks to an egr solenoid off a 92 accord. i wired its yel/black cable to another yellow black cable i had near my shock tower and the other cable to pin A17 on the ecu. well the thing works it opens up at start up and allows vacuum, but at 4900 rpm it does not cut-off vacuum as its supposed to. i heard there is an extra cable involved, could this be whats stopping from functioning correctly?
Old Nov 30, 2012 | 08:45 PM
gstrudler's Avatar
Default Re: wiring iabs
If it's part of the same thread as your old one (which it is), please keep this all together in the same thread. If you're going to do your own work on your car, I highly recommend getting the Helm's manual for it (www.helminc.com); it has all the wiring diagrams you need.
Old Nov 30, 2012 | 11:27 PM
holmesnmanny's Avatar
The egr solenoid should only be working from 1500 to 3000 and at light and steady throttle. You probably have your vacuum lines incorrect.
01ethansh
Apr 19, 2008 07:37 PM
white4doorsi
Aug 13, 2007 01:46 PM
cua0
May 10, 2007 05:16 PM
crxisty
Dec 5, 2004 06:26 AM
