WTB: 99 00 Civic Si parts
Looking for the rear sway bar pieces from the Si - brackets, bushings, endlinks, etc - everything to put a rear sway on a non-Si model.
Also would like to get the black steering wheel/airbag and black plastic steering column covers.
Thanks for any help!
Oh okay, thanks for your response. So there are no black 6th gen steering parts?
I was trying to get black to match the cluster, HVAC controls, and shifter surround, for a sort of "custom" two-tone deal. I'm not sure the dark gray would give the result I'm looking for.
Honda used to furnish black steering wheels regardless of interior color... the gray in my LX just couldn't be more boring, blending in with the expansive dash plastic.
I have an Eibach 17mm rear sway with Si endlinks and d-brackets. Not separating it though. I assume you have a sway already, but if not, check my signature and text me at the number in it and we can work out the details
I have a Civic Type R Steering column cover w/ Map light and ignition light if you are interested in something like that. Check my threads and see if you are interested.
I have a ASR subframe brace and sway bar for the 96-00 civic. Works way better than a stock one, I alsao have the front sway bar for a 96-00 civic came off a CTR.
stuie08
Nov 25, 2006 02:30 PM
