h22a4 to f20b swap wiring help
Old Nov 30, 2012 | 03:57 AM
markvdb's Avatar
Default h22a4 to f20b swap wiring help
I had an h22a4 in a 97 prelude that blew.
I bought an F20B motor, tranny, chipped obd1 ecu, ecu adapter harness, and installed it according to the sellers instructions (zerolift autolabs)
I switched the h22 intake over to the f20b, used the h22 wiring harness, as per zerolift instructions and bought a rywire usdm to obd1 distributor adapter harness. I need to add connections from the 2 wire plug, rpm and power into the diz. Anybody know where to connect these?
Hooked it all up and have crank no start.
With a multimeter, there is power coming from the internal coil spring if I ground the multimeter to battery while cranking.
The distributor is a TD 94U, 8 pin if that helps.
Yeah, I'm a noob and an old one at that.
The coil in the distributor tests out at 2.6 ohms pos to neg, and 15600 ohms at the tower. A bad coil?
HELP! and Thanks.
Old Dec 2, 2012 | 11:24 PM
f20bprelude's Avatar
Default Re: h22a4 to f20b swap wiring help
are you using the old distributor, or a new one? if the old one, does it have an external coil?
H22hatchin
Nov 10, 2008 03:57 PM
H22hatchin
Nov 10, 2008 03:56 PM
PNPFLIPPED
Jun 19, 2006 07:55 PM
ozzyman
Oct 1, 2003 09:52 AM
