need help heater dont work
Old Nov 29, 2012 | 10:35 PM
pinoysi2000's Avatar
Default need help heater dont work
i own honda civic si 2000 with gsr engine
got a new tstat
blower blows hard but still no heat comin out.
also went to the shop and told me my hoses are swtch up and i switch them up and still no heat comin out. please need help
http://i47.tinypic.com/5btq3n.jpg
http://i46.tinypic.com/2n7eqx.jpg
thanks
Old Nov 30, 2012 | 01:35 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: need help heater dont work
Are both your heater hoses hot?
http://autorepair.about.com/library/a/1g/bl899g.htm
Old Nov 30, 2012 | 05:42 AM
kyden's Avatar
that hose doesn't go to the intake manifold.
one heater hose goes to the water pipe under the intake manifold, the other to the nipple on the transmission side of the head.
it actually appears none of your water hoses are hooked up correctly.
Old Nov 30, 2012 | 09:28 AM
Mintyek's Avatar
Have you check your Fuses?
Old Dec 12, 2012 | 02:49 AM
sk8member's Avatar
Grab upper radiator hose and rev it a little ~ 3k if a surge is felt, your water pump is good. Sounds like a bad water pump to me though.
q16racer
Honda S2000
Nov 14, 2011 10:58 AM
2kgsrt
Apr 5, 2010 09:00 PM
mac_24_seven
Dec 29, 2008 01:27 AM
Ohmster
Apr 21, 2008 05:13 PM
greasemonkee
Nov 24, 2006 01:22 PM
