my peddle is so hard
if you have a cable conversion on you tranny is it normal for your peddle to be alot stiffer because your pretty much using your leg to move that hydro tranny?????
yea not so much it may be maybe a little bit but shouldnt be super hard go back look at the lines and make sure there are no kinks in it and then make sure that anywhere that holds the cable that its not crushing the protection sleeve and if you still dont find it make sure that the line is not super dry to the point it may not want to slide at all but if that doesnt work take all the lines out double check that its not frayed anywhere thats what i would start with anyways.
MANDO6669
Jun 7, 2006 09:19 PM
seeeya04
Jun 6, 2005 08:21 AM
