NJ: Garage sale New/used turbo parts and OEM Engine/Trans/Exterior parts
Hey Guys,
I’ve got a ton of parts that I will probably never wind up using as my friend has abandoned his build. Feel free to PM me with offers. Send me your email address and I can respond with pics as well.
Items still available:
• Complete D16Z6 (SOHC Vtec) motor with Brand new D15/D16 FJT Rebuild Kit Included (not installed) - $500
-75.5mm YCP Vitara Piston kit
-Custom FJT I-beam rods
-Hastings Rings
-ACL Bearings/Thrust Washers
-Complete gasket set (for a D16z6)
-OEM MLS Head Gasket
-GMB water pump
-OEM Timing Belt
•Brand new D15/D16 Spoolin Performance (SPFab A/C friendly manifold and dump tube - $300
-Professional black ceramic coating
•New Turbonetics Evolution Wastegate 38mm - $175
•Used Greddy Turbo Timer- $25
•OEM Injector Resistor Box - $15
•Used Apexi VAFC - $75
•ACT HC5-XTG6 –6 puck clutch w/ pressure plate used for 10k miles (fits any SOHC motor, used for 10k miles) - $75
•Fidanza 7.5lb Aluminum Flywheel - (fits any SOHC motor, used for 10k miles ) - $50
•4 RC 550 Injectors (used but in perfect working order – no resistor box required for these) - $225
•Garett T3/T4 57trim Turbo (Will need a rebuild) - $125
•D16z6 Vtec Solenoid - $50
•D16z6 Vtec head - $125
•Used D15/D16 starter - $25
•D16Y8 Intake Manifold - $25
•Auto meter boost gauge, voltage gauge Air/fuel gauge - $20 each
•96-00 Hatchback Tailights - $60
•New fiberglass body kit side skirts for 92-95 Coupe unpainted Email for pics - $30
•New fiberglass body kit side skirts for 96-00 Coupe unpainted Email for pics - $30
Absolutely NO TRADES. I am willing to negotiae but lowballers will be ignored as all prices are fair for a quick sale.
Local pick-up only. I am located in northern NJ (about 15-20 min from the GWB/Lincoln & Holland Tunnels)
Thanks!
-Hastings Rings
-GMB water pump
-OEM Timing Belt
Thanks!
Freshdot
Oct 31, 2016 09:57 PM
EternalSessions
21
Oct 28, 2011 03:14 PM
DelSolDon
May 22, 2007 10:54 AM
DelSolDon
Mar 30, 2007 12:41 PM
