Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Having trouble changing your air filter?
Old Nov 28, 2012 | 02:10 PM
BLKFLSH's Avatar
Default Having trouble changing your air filter?
I got tired of fighting with the air filter box lid, when I wanted to check the air filter. So when I noticed the air tube was split open at the bottom near the throttlebody, from all the pushing on the lid trying to get it out from under the fender, I decided to do something about it. Since the main problem was getting the lid above the fender, I decided to try and cut a notch out of the fender flange, to allow more room for the lid. After removing the plastic trip piece, I noticed there was a fender support bracket in the area. I didn't think the bracket was really necessary, so I cut it off, and bent/folded the fender flange under, about 1/2" to 3/4". Then I used a dremel to trim the plastic trim piece in that area. I took a picture of the finished product to show what I ended up with. I can now change the air filter easily, and I don't have to worry about damaging the air tube.
Old Nov 29, 2012 | 06:28 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Having trouble changing your air filter?
I know the struggles you are talking about, but it's becoming a distance memory because I now don't need to check it that often with K&N. I'll retrace your write up when I do check/clean the next time.
Old Nov 29, 2012 | 01:11 PM
BLKFLSH's Avatar
So, the K&N doesn't get dirty? I know you don't have to replace it, but you should still have to check and clean it every now and then. I noticed you have an 8th gen. Does the 2010 have the same issue? For the first few years, I checked the filter more often, not knowing how quickly it would get dirty. Now that I know it takes a while, I don't check it as often. I should have done this (chopped up the fender flange) years ago, before I ended up splitting the air tube open. I know it doesn't look great, and I could have done a neater job, but form always follows function with me. I just wanted to make changing the filter easier, and less damaging, not really caring what it looked like.
Old Nov 29, 2012 | 01:25 PM
GoLowDrew's Avatar
Old Member
25 Year Member
K & N does get dirty too. Maybe it's lazyness on my part, but I kind of have an idea on "when" I need to check and clean it. So I stick by that.
I have a 8th Gen now and had a 7.5 Gen I4.
Back in the old days when the air box was held by clips, I would check very often.
Old Nov 29, 2012 | 02:00 PM
BLKFLSH's Avatar
So does the 8th gen have the same problem? Or did Honda fix it?
Old Nov 29, 2012 | 06:54 PM
94vtecmn's Avatar
I recently replaced mine with an AEM V2 CAI. But taking that stock air box out was a pain. I can see how just trying to open it would be even tougher.
Old Nov 30, 2012 | 06:23 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Dare I say I only open the air box once since I got my 2010 Accord. It was when I put in the K&N. So I don't recall.
Yes, Bad GLD. I should check and clean it next week. This week(end) I'm busy.
Old Dec 1, 2012 | 05:40 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
FWIW the OEM Honda filters are pretty good for about 30k. There really isnt a need to "check" the filter. Replace it at the proper intervals and youre good.
Old Dec 1, 2012 | 09:29 PM
BLKFLSH's Avatar
Wouldn't that depend on the air you're driving in? It's sugarcane harvesting time right now, and there's a lot of dust lately. It rains, and the tractors drop mud on the road. Then it dries, and you're driving in dust. It all depends on the weather.
Old Dec 2, 2012 | 02:46 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Good point.
<<<<<<<<*lives in Southern CA and is ignorant to other climates and environments that aren't paradise-like*
Nohawk
Sep 21, 2006 05:21 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
turbosi03
Jun 18, 2005 05:36 AM
muskrat
Aug 20, 2002 08:21 AM
Flyboy
May 16, 2001 04:35 PM
