1995 Accord Wont start
Old Nov 28, 2012 | 08:40 AM
Ghostsaww's Avatar
Default 1995 Accord Wont start
I have a 1995 Accord lx with a 2.2l in it. Will not start. I pulled into McDonalds the other day, shut the car off, and walked inside. When I came out, the car would not start. It will crank very strong but wont start.
I have checked the following:
No fuel pressure; fuel pump does not make any noise to prime.
No spark; checked it with a spark plug grounded to the block, no go.
Main relay; I replaced it with a new one, no go
Fuses; All fuses are good
The check engine light is NOT on. Not sure where to proceed next. Any help would be greatly appreciated
Old Nov 29, 2012 | 04:25 AM
adan86's Avatar
Default Re: 1995 Accord Wont start
Same like my honda.. I use H22A.. When I start engine don't make any sound... Is it throttle body problem or stater problem? I use S90 70mm throttle body and wolbro fuel pump.. Please help...
Old Dec 2, 2012 | 01:58 PM
TrickshoT_CD5's Avatar
well if ure using a walboro 255 u would deff hear it prime up so u either have an open circuit somehwhere before the fuel pump, a fuse went bad or ure pump went on you
Old Dec 2, 2012 | 09:35 PM
Hondaguy83's Avatar
Double check fuse under good and under dash. Relays too. Get a wiring diagram and trace it back. Some alarm system will disable those features also.
egb16civic
Honda Civic (2001 - 2005)
12
Jul 21, 2013 11:45 AM
blow1987
Sep 30, 2012 05:28 AM
nova1370
Apr 30, 2012 07:07 AM
em1_racer
Jul 19, 2011 10:52 AM
