Knocking Noise Front Right Side, when driving on bumpy roads
Old Nov 28, 2012 | 05:47 AM
Dunks's Avatar
10 Year Member
Default Knocking Noise Front Right Side, when driving on bumpy roads
Hi Everyone,
I have this knocking sound coming from the front right side when driving at slow speed on bumpy roads, I just had new OEM Struts installed, and I'm still hearing the noise. While driving on good roads and at higher speeds there's no problem.
Could it be mounts gone bad or tie rod ends?
Anyone else experience this problem?
2005 JDM Honda Integra Type S
Old Nov 28, 2012 | 06:53 AM
SickSi99's Avatar
Default Re: Knocking Noise Front Right Side, when driving on bumpy roads
Could be your cv axle popping.
Old Nov 28, 2012 | 09:11 AM
prelude_h22vtec's Avatar
Are the top hats new as well? Make sure everything is tight. Check your Tie rod(edit: sway bar) end links, if they are bad, they can make noise on bumps.
Old Nov 28, 2012 | 03:25 PM
R0FLK0PTR's Avatar
start with the easiest thing. ball joints. take wheel off, try to pull brake rotor towards you and away from you. if its solid, rule out ball joints for now. check for any loose links/nuts. check your tie rods. take it on a road test etc etc see if it clicks when you turn a certain way or not.
Old Nov 28, 2012 | 05:19 PM
kingteg's Avatar
Check your sway bar endlinks. I have had a few with the symptoms youve described. They ussualy end up hitting the subframe causing this noise over bumps, ect.
Old Nov 28, 2012 | 09:40 PM
Lambo123's Avatar
I'm thinkin cv axle on this one but try moving your wheel side to side then up and down. If the wheel moves side to side then you have a tie rod problem. If the wheel moves up and down then you have a ball joint problem. Btw, how lowered are you?
Old Nov 29, 2012 | 04:43 AM
Dunks's Avatar
10 Year Member
Thanks Kingteg,
I'll ask my mechanic to check those links out.
Duncan
Old Nov 29, 2012 | 04:48 AM
Dunks's Avatar
10 Year Member
Hi Lambo123,
I was lowered with Tokico blue struts and Ebach Pro Spring kit about an inch, but when those struts went bad a couple months ago I could not get anymore Tokico Struts for DC5 they have stopped making them so I'm back to OEM struts and springs again Lol
Duncan
Old Nov 29, 2012 | 01:15 PM
kingteg's Avatar
No prob. Its common when they come in, so I thought Id share. Let us know.
Old Dec 2, 2013 | 11:05 PM
pawan.nikunsh's Avatar
Originally Posted by Dunks
Hi Everyone,
Guys I m also facing the same problem...I m having honda city zx 2006 model
Can any one help...
Old Dec 3, 2013 | 05:46 PM
WanaBeFaster's Avatar
CV axles aren't typically going to pop going over bumps. ball joints, and end links are most common
Old Dec 25, 2013 | 07:25 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Compliance bushings are the most common fault. Far more so than balljoints on this vehicle.
Old Jan 6, 2014 | 08:42 AM
Cristiang305's Avatar
The bolts that hold your motor to your car I had the same problem now I don't know what it's called but you should look right under where your headers are mine was missing one nd the other was loose that really made a horrible noise almost like a C.V. axle popping only in the bumps it would do that took me a while to figure out bought axles nd new struts springs everything man turned out to be those bolts so just look maybe that's it hope it helps man.
1badcrx
May 13, 2011 09:05 PM
vermontsol
12
Aug 16, 2009 05:23 PM
int3gra07
Dec 3, 2006 01:45 PM
cd5_2NR
Jul 24, 2004 06:45 AM
NCSTIdriver
May 11, 2003 08:38 AM
