tien ?
Old Oct 18, 2002 | 08:15 PM
tunedcivic's Avatar
Default tien ?
i had some old tien full race coilovers, and i sold them when i was selling the car. but now i kept it, and i am saving for new coilovers. my question is why they dont offer the electronic damper force controller for our car. i called tien and he said the motor didnt clear the hood...but that doesnt make any sense? any ideas?
Old Oct 19, 2002 | 01:45 AM
Jaker's Avatar
Default Re: tien ? (tunedcivic)
The little electric motor that turns the shock adjustment when you make a change using the controller inside the car sits on the top of the shock in the engine compartment and wouls be too high to clear the hood when you try and close it.
Old Oct 19, 2002 | 04:29 AM
tunedcivic's Avatar
Default Re: tien ? (Jaker)
so is there any way to use it? i mean is that what you think, or ias that a fact that the motor wont clear the hood?
Old Oct 19, 2002 | 05:48 AM
Jaker's Avatar
Why don't you just buy the ****, and try it. Chances are that if Tein says it won't fit, then it likely won't fit.
Old Oct 19, 2002 | 10:22 AM
tunedcivic's Avatar
tien just said they didnt make them...but the hex adjustment on the strut is the same size on all of their products, so I would wanna see if the motor would work
Old Oct 19, 2002 | 10:53 AM
ijjz's Avatar
just don't use a hood.
Old Oct 19, 2002 | 12:47 PM
USDM 4G VTEC's Avatar
Default Re: tien ? (ijjz)
i wish i could do that without getting pulled over!
Old Oct 19, 2002 | 01:24 PM
oldskool_rex's Avatar
the EDFC is a universal kit that works on all tein adjustable shocks. When they say it won't work they mean that there is not enough room to mount the motor on top of the shock without the hood smashing the **** out of it.
I would get it and then put spacers under the hood hinges to jack up the back of the hood, thus making more room for the motors.
Old Oct 19, 2002 | 01:29 PM
xtrafastcivic's Avatar
Default Re: tien ? (oldskool_rex)
why do you want it anyways??? you can just go outside and adjust it manually....
Old Oct 19, 2002 | 03:07 PM
tunedcivic's Avatar
Default Re: tien ? (XtraFastCRX)
it is a pretty cool idea, i think. saves me from getting dirty. its easy, but asides from that, nobody around has it, and i think the idea is awesome for under 400 dollars. in terms of no hood, i love the look, but i got pulled over. i have a fiberglass hood so, shimming it too much would create a nasty gap. anyways I think i might go for it...cool to see if it will work.
Old Oct 19, 2002 | 04:56 PM
to tell yuo the truth i think it would work without shimming the hood up... i personally think tien doesn't care much about the ef chassis like most other companies... just buy it for the integra or civic and change your front forks and rear LCA to 88 crx\type r and you'll be set...... but i think paying 380 isn't worth it....
edit: i was saving up for tiens, but now i'm thinking of zeal or jic...
[Modified by XtraFastCRX, 5:57 PM 10/19/2002]
Old Oct 19, 2002 | 04:59 PM
bryant's Avatar
You have to change out the rear LCA's with any tein or aftermarket Japan suspention. I alreddy Emailed tein askign them about the EDFC and they said the only reason it wont fit is becuase of hid clearence. Im not sure how much more room you have to have, but when i was at the honda tech Hybrid Dog Meat in cali. Merrit had some on here EK. and that **** sits pretty high up there.
Old Oct 19, 2002 | 05:20 PM
Default Re: tien ? (CR-X)
not if you have an 88 like me i don't have to change anything if i bought tiens ha.... never saw the edfc for honda in person.... saw it on a nissan
Old Oct 19, 2002 | 05:31 PM
bryant's Avatar
Oh yeah forgot about them 88's
Old Oct 19, 2002 | 07:03 PM
sporkcrx's Avatar
no problem! put two hoodscoops over each strut tower!
Old Oct 20, 2002 | 09:21 AM
Cuz it is freaking DOPE MAN! It is fun to play with. Yeah, you don't need it, but if you had it you would be fooling with the thing all the time....
It even has 3-4 presets, so you can talor each preset to a certain portion of a track, or even a certain road condition. If you are on the street, you could have a preset for freeway, city, construction site, rally.........you name it!
Feakin. Dope. Man.
[Modified by oldskool_rex, 10:22 AM 10/20/2002]
Old Oct 20, 2002 | 09:50 AM
FourthGenHatch's Avatar
Have you ever noticed the large bumps on a Dodge Stealths Hood on the sides? If I were you I would cut holes in my hood and just put some kind of bumps like that over to make a space for the motor to fit. It might also look cool to.
Old Oct 20, 2002 | 11:43 AM
altoid's Avatar
Default Re: tien ? (FourthGenHatch)
exactly what i was thinking throughout reading this entire post
Old Oct 20, 2002 | 03:12 PM
You could very well do that, but you might not make enough room that way, and I think hikinh up the hood looks cooler. Plus, it is super simple to do.
shutuprichard551
13
Aug 22, 2009 09:53 PM
mmvito
Aug 4, 2009 12:58 AM
Setsuna F Seiei
Suspension & Brakes
22
Jan 29, 2005 08:38 AM
The_Todd
Jan 21, 2004 06:39 PM
Farrell
Jul 27, 2002 12:03 PM
