where to go with my build (intake wise)
Old Nov 27, 2012 | 12:43 PM
shocker911's Avatar
Default where to go with my build (intake wise)
my build is almost done i have no idea what to do for intake system. I figure my compression to be around 12.3:1.
my build
B18A (81.5)
P73 pistons
LS rods
B16 head (slightly ported to clean up castings and gasket matched)
Super tech valve springs and retainers
Ferrea flat faced valve
Rocket M22X cams
PLM header the SP series to a 3 inch thermal exhaust
Its going in a CRX.
I do have these parts laying around 70 mm Skunk2 TB, Skunk2 intake manifold, 3 inch V-stack.
Would this be a decent intake or should i just bite the bullet and go ITB. This car is mostly a weekend car that will do road X and 1/4. Im trying to get the MAX HP i can out of the motor. Any ideas or suggestions are appreciated.
Old Nov 27, 2012 | 04:08 PM
bks84's Avatar
Loved
Default Re: where to go with my build (intake wise)
I dont see how youre 12.3:1 w/P73's and a B16 head. According to Zeal youre around 11.6:1 static...
anyway, personally i'd stick with a manifold over ITB's, I dont think you'll benefit much from ITB's.
Old Nov 27, 2012 | 04:16 PM
AllMtrRex's Avatar
you would be right if he said P73-A0 (usdm itr).....with the P73-00 (jdm itr) he is right...
Disco's Avatar
Use the parts you listed they will work well.
JPerkMr954
30
Nov 3, 2015 04:34 PM
shocker911
10
Aug 31, 2012 06:42 AM
advaneh3
11
Mar 19, 2009 01:44 PM
futrhondaownr
Oct 11, 2008 01:11 PM
bounty359
Oct 1, 2005 12:29 PM
