Looking for a good front big brake kit?
Old Nov 27, 2012 | 08:41 AM
batto24GSR's Avatar
Default Looking for a good front big brake kit?
looking to buy a good big brake kit that wont hurt my wallet too bad any suggestions and opinions? post pics of your pic brake kits on your 94-97 GSR
Old Nov 27, 2012 | 09:04 AM
akcapr's Avatar
Default Re: Looking for a good front big brake kit?
Im selling my wilwood big brake kit for civic/integra. Its hardly used, has stainless braided lines, brand new pads. I bought it for 900 new, but im selling it for 550$. Heres a link to my add, hit me up if interested.
http://www.google.com/url?sa=t&rct=j...T01-c7z0-QwxoQ
Old Nov 27, 2012 | 09:12 AM
doood's Avatar
been there done that
Why?
Old Nov 27, 2012 | 11:03 AM
batto24GSR's Avatar
any good reviews on any? trying to find a good kit thats under a grand
Old Nov 27, 2012 | 11:38 AM
jazzRS's Avatar
11" cooper rotors with legend twin pistons??
Old Nov 27, 2012 | 12:15 PM
batto24GSR's Avatar
would it be better to purchase the rotors, calipers,pads, and brake lines all separately or all in a kit
Old Nov 27, 2012 | 12:25 PM
batto24GSR's Avatar
http://www.jhpusa.com/store/pc/viewP...idcategory=119
what about this
Old Nov 27, 2012 | 01:19 PM
Schister66's Avatar
Man U FTW
Originally Posted by doood
Why?
The most insightful thing said in the thread so far...
Without knowing what you want, aside from "big brakes", we can't offer useful advice. You need to be more specific. Until then, my suggestion is a set of Brembo blanks and Hawk APS pads...cheap and effective (and often, still more than people really need)
Old Nov 28, 2012 | 09:17 AM
batto24GSR's Avatar
im looking for kit with either slotted or drilled rotors with stainless steel brake lines good pads bigger calipers for a reasonable price, and i want to make sure its a lot better than stock otherwise i would just keep all my stock **** and not waste the time and or money
Old Nov 28, 2012 | 09:43 AM
Schister66's Avatar
Man U FTW
I used to run Brembo x-drilled and slotted rotors on my GSR. They didnt fade as much on the drag strip, but ate brake pads pretty quickly. I never upgraded the lines, but i wasn't out autocrossing it and beating the brakes repeatedly. This is where knowing your goals would help. Its easy to find the parts to fit your description, but are you really buying what you need..? And "reasonable price" doesn't give us anything either...whats reasonable to me, might be 3x what you wanted to spend.
Old Nov 28, 2012 | 02:24 PM
batto24GSR's Avatar
well this spring i was thinking about autocrossing my car and just wanted a solid reliable upgraded that wont break my bank
Old Nov 28, 2012 | 04:12 PM
Solidis's Avatar
This is what i bought in they get the Job Done..
http://www.ebay.com/itm/250599194874...84.m1439.l2649
and http://www.ebay.com/itm/250878962422...84.m1439.l2649
I was on a budget.. less than $100.00 bucks i just dont go cheap on brake pads.
I will be Upgrading them to something better.. I like the way wilbrook looks.. gunna do research.. i got a 96 GS-R.. Ill be starting a thread on my build..
Old Nov 28, 2012 | 04:13 PM
TypeRfit's Avatar
RESIDENT
Wilwood is probably your best bet for price/quality.
Old Nov 28, 2012 | 05:51 PM
doood's Avatar
hawk hps or hp+ pads, ate super blue fluid, blank rotors, stainless lines. done. if you want you can do nsx calipers and prelude rotors.
still a hell of a lot cheaper than a bbk and i seriously doubt you'll push them to the limit.
Old Nov 28, 2012 | 09:13 PM
batto24GSR's Avatar
i honestly dont want to be buying this cheap **** for 40 bucks for rotors?... i know from experiance you get what u pay for
Old Nov 28, 2012 | 09:18 PM
batto24GSR's Avatar
another question has anyone ran into problems not being able to fit wheels on certain types of different big brake kits?
Old Nov 29, 2012 | 04:08 AM
USMCxTeg's Avatar
Have to make sure you have clearance room inside the wheel, so whatever the distance between your current rotor/caliper is the added size of the bbk can't be greater or it won't fit.
Also, if you get a bbk you gotta have tires with enough grip to actually use that added stopping power. If your current tires lock up with your existing brake setup then they will likely need an upgrade or you won't be able to utilize the bbk! Learned that from experience, lol, cheap tires on an Evo 8 I used to own.
I'm gonna go with brembo blank rotors and hawk pads (need brake service anyways) after my ls/v gets out of the shop for cv axles and then the body shop. Got backed into at a red light by an Expedition...
Old Nov 29, 2012 | 05:33 AM
Eight09's Avatar
http://www.team-integra.net/forum/19...ml#post2575516
Old Nov 29, 2012 | 11:18 PM
batto24GSR's Avatar
okay im liking everything i am hearing anyone else that would like to share their BBK or upgraded brakes?
Old Nov 30, 2012 | 04:56 AM
Dogginator's Avatar
Daisy... Daisy...
I track my car with ITR front calipers and 282 mm 92-96 Prelude VTEC rotors redrilled to 4x100mm. Pads are Hawk HP Plus with Motul RBF600 fluid. This can be done a lot easier now with 280mm Mini Cooper S front rotors and ITR calipers without any machining.
See this thread.
How to: 11 inch brakes on 3rd gen
Last edited by Dogginator; Dec 5, 2012 at 11:00 AM. Reason: Corrected Mini rotor diameter
Old Nov 30, 2012 | 10:04 AM
batto24GSR's Avatar
im kinda wanting to stay with a BBK kit that is actually meant to be on a 96 GSR if you know what i mean, i dont want to be buying all these different parts from different cars and putting them all together
Old Dec 5, 2012 | 10:13 AM
batto24GSR's Avatar
any other integra owners have BBK that want to share?
Old Dec 5, 2012 | 10:42 AM
mickeydog's Avatar
put some tl brakes those are really nice.
Old Dec 5, 2012 | 10:43 AM
mickeydog's Avatar
might be a little pricey
Old Dec 5, 2012 | 01:36 PM
Local's Avatar
the mini cooper + itr caliper upgrade everybody is linking you is really your best bet. try not to disregard it just because its marketed as a mini cooper rotor. it is direct bolt on for your 96 integra, no need to worry about fitment. the kits start at ~$150 and come with everything you need.
http://store.propartsusa.com/propart...e/g-67436.aspx
Jdm...
Jul 4, 2006 08:50 PM
97spooncivic
Nov 2, 2005 02:27 PM
Dveloped
Nov 1, 2003 09:17 PM
Mr Samson
Dec 23, 2002 03:42 PM
