2012 XMAS clearout (K-series and B-series parts)
Old Nov 27, 2012 | 06:52 AM
CHEETAH's Avatar
Default 2012 XMAS clearout (K-series and B-series parts)
very negotiable on many parts that is just sitting, so just inquire via PM. will get pics online and post, but can email them...
K-series parts:
1) misc rocker arms, cam holders, mostly single lobe setups from Accord and CRV setup $inquire (very cheap); Accord heads $75 each with intake manifold; Newer style R40 Accord head $50
2) misc tranny gearsets and loose misc tranny parts, forks, syncros, gears, etc. $inquire
3) K24 turbo friendly 87mm bore low compression pistons and aftermarket rods used $500; with bare K24 block and crank $900 (unassembled)
4) K24 (newer style R40 blocks) 88mm bore new 12.5:1 compression all motor shortblock with RSC waterpump, alternator, R40 intermediate shaft and R40 oilpan and chain cover...$1200
5) 102mm stroker x 90mm bore K20 complete shortblock (made 340whp on pump e85 with portflow head), s2k oilpump with ERL kit, 15+:1 compression used one season in very good condition ...$3000neg
6) 2x EP3 shifter and cables...$75; misc k-series throttle bodies and parts $cheap
7) OneFab ramhorm turbo manifold $500
8) RSX new aftermarket K-wap s/s header $300
9) 2 x PRB RSX intake manifold $35 each
B-series parts:
1) $will sell cheap - many b-series distributors and parts including caps, housings, magnetic pickups, etc.
2) $will sell cheap - b-series tranny parts, gearsets, shafts, forks, etc. very heavy crate full of misc tranny internals...
3) 1 - B16a block, $75 bare with main caps and fresh hone (just needs cleaning)
4) 2 x GSR intake manfold $35 each
5) misc b-series throttle bodies and various parts $cheap
6) found a set of very clean but used wiseco 84.5mm bore endyn rollerwave pistons, prolly about 12.7:1 compression...$300
7) also have a set of used but also clean condition 84.5mm bore Wiseco/Endyn rollerwave pistons for 92mm stroker setup about 13:1 compression or more...$275
8) 86mm bore b-series high compression pistons, used but clean, I think Arias...$250
email g b r t u n i n g at a o l dot c o m or PM me here...located in NJ
Old Nov 28, 2012 | 07:20 PM
JerseySiPOS's Avatar
Default Re: 2012 XMAS clearout (K-series and B-series parts)
Bump
Old Nov 28, 2012 | 08:36 PM
Lambo123's Avatar
What kinda pistons on that 12.5 k24 block?
Old Nov 29, 2012 | 04:13 AM
CHEETAH's Avatar
its CP pistons...thanks for the bumps.
Old Nov 29, 2012 | 01:15 PM
Ratt731's Avatar
Bump
Ratt731's Avatar
Pm sent
Old Dec 1, 2012 | 04:57 AM
mar778c's Avatar
Community Builder
Community Influencer
I need a the b16 block with crank. Check PM.
Old Dec 3, 2012 | 06:23 AM
CHEETAH's Avatar
sold stuff and added stuff...
skyler84
Jul 19, 2013 06:38 AM
AzNKhMeRrAcErNzA
Northwest (Sales)
Jul 17, 2009 03:22 PM
allmotorh22
Dec 11, 2007 08:35 PM
