91 Civic - injectors don't pulse
Old Nov 26, 2012 | 04:29 PM
Dandada's Avatar
Icon2 91 Civic - injectors don't pulse
I have a 1991 honda civic dx which I recently converted from dpfi to mpfi via Monotech conversion harness. I am using a d16y7 motor and a obd1 intake manifold & injectors. My dizzy is obd0 si my ecu is pm6 wich is pbd0 si ecu. My problem is that my injector dont pulse. I have power the fuel pump so I have fuel pressure. I have spark comming from dizzy all my grounds checks out jus find. I also change my main relay. And I thought it was my ecu so I borrowed a dizzy & ecu from my friends working si and still I don't get pulse. Any one that help me with my problem I am very greathful.
Old Nov 26, 2012 | 04:31 PM
tonylovesjdmEF9's Avatar
Default Re: Please help! ASAP
i see that you live in the ie well if i was you i would check your wiring where did you end up plugging in the pins on the ecu.. also what type of injectors are you using?? and pics ???
Old Nov 26, 2012 | 05:25 PM
91legend's Avatar
Also, if you have a multimeter, check to see if you are at least getting power to the injectors.
Old Nov 26, 2012 | 06:14 PM
Former User's Avatar
Default Re: 91 Civic - injectors don't pulse
Tip: Please create a thread title that summarizes your technical problem/question so that members quickly understand the topic without reading your post. This helps you to get more useful responses by letting our members know exactly what technical information that you need -- Title edited.
Old Nov 26, 2012 | 10:19 PM
^^^true that
your problem is gonna be in your wiring set up. all you gotta do is diagnose the injectors.
is the fuel at the right preasure?
are you getting power to the injectors??
are the grounds on the injectors good?
did you de pin and repin the harness to the ecu right??
it could be many things its up to you to read, search and try
Old Nov 28, 2012 | 07:10 PM
Dandada's Avatar
Ok thanks guys for all your post. I am using obd1 injectors so I illuminated the resistor box.
I am having voltage by the injectors, & all my grounds checks out jus fine. I've checked n rechecked all the plugs for the harness over n over.
Old Nov 28, 2012 | 07:32 PM
crx_si-r's Avatar
recheck the harness. if im not mistaken monotech sells them on ebay. if you have the harness i think you do, its a used harness that has been modified. chances are some of the wiring may be damaged. you can contact him directly or take apart the loom and inspect the wiring personally.
Old Nov 28, 2012 | 07:48 PM
CEL codes?
Have you tested the crank sensor in the distributor? Its signal is needed by the ECU to control injector timing.
Old Nov 28, 2012 | 11:04 PM
umm i used monotech many times hes work is clean been running a obd0 to obd1 conversion harness in my ef and no problems and everything was new when i got it.
do you mean you eliminated the injector box????
if so did you do it the right way of using the obd1 block plug were you get all the grounds of the injectors and the gound of the resistor box into one single plug???
he did say he used a different dizzy so yeah im sure the problem is going to be in your wiring (wrong pin out used when you pluged the harness, the injectors are wired wrong)
Old Nov 29, 2012 | 05:00 PM
Dandada's Avatar
Yes I did mean eliminate sorry for misspelling. N no I didn't used the obd1 block plug. How do u test the crank sensor on the dizzy. N I check the 2 wires on each of the injectors with a continuity tester n they check out jus fine. N I agree that Monotech work is clean n professional.
Old Nov 29, 2012 | 06:23 PM
EF8DayDreamer's Avatar
check resistor box!!! if its defective you wont get power.
Old Nov 29, 2012 | 06:58 PM
swordofdoom's Avatar
Check to see if the correct pins on the ecu are actually going to the correct injectors.
Old Nov 29, 2012 | 09:20 PM
okay so then you just solder the wires together or ghetto rigged it ????
the problem is going to be in your ecu pin out or in your cancelation of the resistor box
Old Nov 30, 2012 | 02:53 AM
splatranger95's Avatar
How did you eliminate the resistor box? You should solder all of the yellow/black wires together which get soldered to the yellow wire coming from the ECU IIRC. Then connect the two wires you ran to the ECU and the two existing wires to the injectors.
Are you sure you have high impedence injectors? What is the resistance of the injectors you have?
Old Nov 30, 2012 | 07:26 AM
crx_si-r's Avatar
chances are that if the harness was made to plug into a resistor box your using low impedance injectors. and by soldering the power wires of the injectors, not the grounds, then your supplying too much power to them.
low impedance iirc are only supposed to receive 5.5v, by soldering the wires together you are now supplying them with 12v. this will inturn burnout the injectors causing them to no longer function properly. a lot of people think that by converting to obd1 you have to eliminate the resistor box, this is not true. the resistor box elimination is solely dependant on which injectors are used regardless of obd0 or obd1.
Old Nov 30, 2012 | 10:19 AM
^^^agreed with him I'm running obd1 ecu and dizzy with everything else except the injectors
Old Dec 9, 2012 | 11:12 AM
Dandada's Avatar
I soldered the power wire behind the plug closer to the box it self. And I'm using hight empedence injectors that's why I did that. N all the wiring checks out fine by the injectors I checked for countunity with a tester n all checks out fine. My main relay is brand new and how do u test the crank sensor in the distributor. And I tanx u all for ur help n support
Old Dec 9, 2012 | 11:14 AM
Dandada's Avatar
How do you upload pics?
Old Dec 10, 2012 | 08:56 AM
Go to the gallery. Or use photobucket
Old Dec 10, 2012 | 12:46 PM
Dandada's Avatar
I'm using my iPhone
Old Dec 11, 2012 | 03:51 AM
That still applies.... or you can host from your phone using imgur.. Look for apps.
Old Nov 28, 2022 | 08:38 AM
Josh Wilusz's Avatar
Did you ever figure this out? I currently have this problem with my Monotech harness on a B series conversion harness for my CRX SI
Mark Hopper
Sep 16, 2013 12:38 AM
Dandada
Nov 30, 2012 06:37 AM
Gkdc182
Oct 22, 2009 01:57 PM
dropNdestroyEF
Aug 2, 2007 04:35 AM
bootlegcivic
Aug 6, 2005 10:07 PM
