cams?? need help
Old Nov 26, 2012 | 03:16 PM
marshall12395's Avatar
Default cams?? need help
im in abit of a pinch. so i wanna chance my cams in my b18c type r. im upgradeding my valve train, and on my car i have headers 421, 2 and half exhaust. so here my queston what kind of cams should i put most of my parts are skunk 2 so i wanna stay with them. what would be the best cams for my setup??
Old Nov 26, 2012 | 05:37 PM
PsychoRex's Avatar
Default Re: cams?? need help
Am putting blox tuner stage 1's on my stock itr engine. 264 intake & 259 exhaust going to run the stock valve train
Old Nov 27, 2012 | 05:39 AM
Dave_B's Avatar
Cams mostly are dependent on your CR. Are the internals stock? If so, you don't want to over cam your motor. You'll actually see a loss.
If stock internals, and your sure about upgrading a Skunk2 Stage 2 may be what your after.
If internals are mod'd and higher CR is gained then you can look into the Skunk2 Pro series.
I've has the S2P1+ cams previously in a track only car. Lumpy idle but I had headwork and upgraded CR.
HTH
Old Nov 27, 2012 | 04:47 PM
coolhandluke's Avatar
Given Skunk2's recent series snapping cams and horrible PR with the whole K20.org bit I see no reason to recommend their products. There are plenty of other reputable companies out with cam options.
OP- We know very little about your setup at this point so a "best" cam right now is really just an uneducated guess.
Motor- internals, valve train, stock rods, etc.
Transmission- What year, final drive, etc.
You need to match your cams with your shiftpoints, to make sure your powerband matches the shift points in your transmission. Otherwise you are just throwing parts onto the car and like Dave mentioned, you might actually make less power.
Old Nov 28, 2012 | 08:57 AM
i have type r lsd tranny 1997 stock final drive. im think of going with a supertec valve train(valves,valves springs, retainers and stage 3 cam tuner series heres what of think of getting.
http://www.ebay.com/itm/Skunk2-Tuner...3bae9c&vxp=mtr.
i have 2.5 exhaust,421 headers, im also upgrading intake manifold,68mm throttle body,aem cold air intake,440cc rc injectors
and of course getting a very good tune
Old Nov 28, 2012 | 10:07 AM
Todd00's Avatar
I said I don't want a title!
Originally Posted by marshall12395
...most of my parts are skunk 2...
Sorry about your luck.
Old Nov 28, 2012 | 10:16 AM
Aquafina's Avatar
Stage 3's will be very peaky with little low-mid on a stock block/head setup.
Old Nov 28, 2012 | 10:30 AM
so what cams would you recommend???
Old Nov 28, 2012 | 10:40 AM
Todd00's Avatar
What are your goals for the car? You building a dragster, roadrace machine, autox car, dyno queen, etc?
How do you expect us to recommend anything when you don't tell us the application in which you're going to use it for?
Old Nov 29, 2012 | 05:07 AM
its car to have fun on the streets with
Old Nov 29, 2012 | 05:27 AM
Aquafina's Avatar
If you're stuck on using Skunk2, I would go with the Stage 1's if you're on a stock block and head.
HyperFlow
Jun 6, 2010 11:55 AM
HitF8
Jun 3, 2010 11:13 AM
The Si
Feb 22, 2007 03:17 PM
hondadriver
11
Oct 1, 2006 10:59 AM
Tuan
Jan 15, 2003 10:23 AM
