can I use my F22B1 ingectors on H22A
Whether the injectors are peak and hold, or saturated, is not the main issue.
The accord injectors are 190cc while the h22's flow at 240cc.
You will run lean, so don't use them.
The 90-97 Accord injectors are all peak and hold and are only 240cc, too small for the H22.
Your best bet would be to get the OBD1 345cc Peak and hold H22 injectors from a 92-95 VTEC Prelude. Then you can use your stock resistor box and injector clips.
spraymysol
Dec 8, 2008 02:48 PM
