'91 civic dx with d16y7 swap
Old Nov 25, 2012 | 12:41 PM
Dandada's Avatar
Icon2 '91 civic dx with d16y7 swap
I have a 1991 honda civic dx with a d16y7 swap. I converted it from dpfi to mpfi I'm using a obdo distributor n obd1 injectors I bought a conversion harness from mono tech n I have spark from the Dizz but no pulse from the injectors. And yes the fuel pump turns on? Why am I not getting anything from my injectors. O n if your wondering wich ecu I'm using its a pr3. If any one can help me out i would be highly greatful for your help.
Old Nov 30, 2012 | 06:37 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: '91 civic dx with d16y7 swap
are you using an injector resistor box on the obd1 injectors? because "there's your problem"... otherwise it sounds like you need to check the conversion wiring for the injectors, because it is not right.
Wagonlife99
Sep 15, 2018 04:03 PM
phatboyzef2
26
Dec 23, 2010 12:30 AM
99DC2GSR
26
Nov 27, 2008 12:40 PM
91dx-92ex
Feb 9, 2006 07:39 AM
rextec
Jul 23, 2005 12:26 PM
