Overheat & no start
I recently intalled a D15Y5 Vtec head on my D15b7. After the install, car started up fine and I ran the car for about 12miles. Came back and car started overheating. Drained and refilled coolant, even replaced radiator with a new one, still having the overheating issue. What I did notice is that sometimes the car will not start, checked the spark plugs and notice they have moisture. Checked compression and it's good across the cylinders. If let the car sit overnight, then start it the next day, it starts up fine. The head gasket is brand new also. Also removed the thermostat, to no avail, still starts to overheat. For some reason, it look like the injectors may have moisture on them after driving the car. Any suggestions will help. Thanks.
fms1day
38
Jul 5, 2006 02:44 PM
