cluster out in ef?
Ok so I was driving down the road in my 90 EF sedan and I noticed my ex clock wasn't on. And then I realized my cluster was just not working at all except speedo. Any ideas on what it is?
Ok I put a new 10a in and the gas gauge went up but rpms and climate did not. Then gas dropped again. I'll check if it blew again though. Anywhere it could be grounding out? Like a common spot
If it instantly pops the fuse, you my friend have a short. Could be in the PCB on the cluster itself, or a wire rubbed too long and frayed itself on the body..... This one is going to take some digging. Its not going to be a different fuse, you would be wasting your time with that.
Youre going to have to pull the cluster off, and look. Also, the fuse will most likely blow before you see an arc on the PCB so its a tough one to diagnose. Look for smoke though.
honda_conversion
Jun 22, 2007 11:31 PM
alupso
Nov 20, 2006 08:38 AM
