96 Civic D16Y8 - need help locating oil leak
Sorry gang, I don't have a manual and not sure what this sensor is. Its leaking oil pretty bad and need to replace it ASAP. This is a 96 Civic ex Vtec Auto trans. Passenger side front of the head just below the distributor. See link for picture of engine. Thank you for the help.
http://www.cardomain.com/ride/241514...c/#24151470007
The oil is coming out of the sensor where the black plastic fitting connects with the insert that screws into the side of the head, this is why I need to replace the sensor but I don't know what it is. The picture shows the sensor I am speaking of, just below the distributor.
The oil is probably leaking from the distributor O-ring. Buy the Honda O-ring to replace and go from there.
Also check for oil inside the distributor and below the VTEC solenoid.
I'll rephrase the information;
I have check the V-Tec solenoid and the distributor prior to this post. Neither are leaking. After cleaning the motor I found the subject sensor is leaking oil. I can watch the sensor bubble oil out as the engine runs. Can someone advise what this sensor is so I can replace it and fix the leak?
Adam V
Mar 12, 2018 07:38 PM
5.4ever
10
Mar 6, 2014 05:27 PM
allm0torGSR
Mar 30, 2004 09:55 PM
