need alternator help
Old Nov 24, 2012 | 07:28 PM
GPC91's Avatar
Default need alternator help
i have a d16zc vtec in my car and my alt is over charging. my car is run on obd1. im just curious as to if the alternator its self is obd sensitive or if it just the plug. like would i be able to use the alt from my 91 civic sedan if i changed the plug on it? if so does anyone have the wiring pin out for this thanks in advance.
Old Nov 24, 2012 | 07:42 PM
4drEF's Avatar
Keyboard Humorist
Default Re: need alternator help
OBD2 is the weird one.
OBD0 and OBD1 are interchangeable.
I don't even think you need to switch out plugs.
In the off chance that you do need to switch plugs, the colors should be the same making it an easy swap.
Old Nov 24, 2012 | 09:23 PM
GPC91's Avatar
that is great news. thank you very much.
Old Jan 29, 2013 | 11:57 AM
GPC91's Avatar
ok i got into looking today and the plug on the obd0 alt looks to be 4 wire. and the obd1 looks like its 3 wire. any thoughts on this? could one of the wires on my obd1 alt came off and thats why it is over charging my battery?
Old Jan 29, 2013 | 12:15 PM
4drEF's Avatar
Keyboard Humorist
Ah... you got a 3 wire =/
Most have a 4, but you can use the 3 anyway.
S- sense I - Ignition and L for light
some have B - battery, but you can leave that disconnected
Old Feb 1, 2013 | 03:02 PM
GPC91's Avatar
alright sounds good to me thanks for the help.
BAZ
Nov 7, 2008 04:25 PM
ATgrills.com
Jun 12, 2004 09:19 PM
ATgrills.com
Jun 10, 2004 05:40 AM
ATgrills.com
Jun 10, 2004 05:39 AM
