Can I use one of these mufflers on my Civic?
Old Nov 24, 2012 | 05:56 PM
civic_jason's Avatar
Default Can I use one of these mufflers on my Civic?
I already own these as they were off of my 2003 Cobra Magnaflow catback system that was damaged during a wreck and a whole new one was ordered and these were salvaged along with some of the piping.
https://post.craigslist.org/k/8twrNh...UqRQ?s=preview
This will be for a B20 swap into my ek Civic (B20 with a p8r head and 9.2cr). I will be using an RMF standard header that has a 2.5" collector. The magnaflow mufflers are 4x9x14 with 2.5" inlet/outlets and I do have some piping left over from it. Apologies for the lack of info in my original post I was mourning over my teams dismantling in college football even though it was expected.
Last edited by civic_jason; Nov 25, 2012 at 12:12 PM. Reason: more info about about upgrades
Old Nov 24, 2012 | 06:12 PM
98civdx's Avatar
Master Detailer
Default Re: Can I use one of these mufflers on my Civic?
Could you? Yes, but it will need to be custom installed.
Old Nov 24, 2012 | 06:25 PM
jbpnoman's Avatar
You haven't told us anything about the inlet size of the muffler, or your current car's exhaust piping size, but anything can be made to fit.
Old Nov 24, 2012 | 09:52 PM
Yes you are right I am lacking info in my post. 2.5" inlet with some 2.5" piping to go with it. I will be having a b20 with a RMF standard tube with a 2.5" collector installed in the next few months so I'm expecting to have a custom exhaust.
This is the exhaust that I have: http://www.americanmuscle.com/ma.html
I was hit in the right side corner so the right tip and some of the piping was damaged. I won't be using the tips regardless but if I can use some of the piping I will. I want the car to be quiet so if I can't quiet it down with a silencer or something I may not use the magnaflows regardless but for money saving I'm considering trying it.
Old Nov 24, 2012 | 09:58 PM
dirty19's Avatar
Ridin Dirty in Cali
Those are a little big for a civic. sell them puppies and use that money for a great fitting one.
Old Nov 24, 2012 | 10:00 PM
98civdx's Avatar
Master Detailer
I agree with above. Put them on craigslist and sell them.
Old Nov 24, 2012 | 10:04 PM
jbpnoman's Avatar
Eh, I wouldn't say they're big for the car - you can make anything fit behind that bumper. I've seen 24" mufflers welded in. I would say they're baffled wrong for a high revving 4 cyl, and will probably sound weird as hell.
Old Nov 24, 2012 | 10:20 PM
98civdx's Avatar
Master Detailer
too big, probably not. You could defiantly get them in there. Hell I bet the stock muffler is just as big.
Old Nov 24, 2012 | 11:34 PM
B20DelSol's Avatar
What is the dimensions of the muffler? 4x9x14" maybe?
IF so...they should fit. I run that size with a 2.25" ID on my B20 Del Sol...Fits tight. If its on a civic coupe (or sedan) though, you should have plenty of room.
They are pretty quiet. Mine is a Center In/Offset Out. I don't know how offset/offset will sound w/ 2.5 ID, but mine is stock sound level at idle and up to around 2k. After that it makes a smooth, mellow tone that is not too intrusive and should not get you pulled over by the cops.
Old Nov 25, 2012 | 06:57 AM
Measured the inlet/outlet and they are 2.5". I think 4x9x14" is correct but I'll double check...just measured and 4x9x14" is correct and so is the 2.5" inlet/outlets. I'm not sure how noisey these things will be but they look to be pretty straight through with only a slight bend where you can see out the other side
Old Nov 25, 2012 | 07:14 AM
They'll be going on a non-vtec b20 so not that hight reving actually not any or much higher reving than the supercharged V8 they came off of.
Old Nov 25, 2012 | 07:27 AM
jbpnoman's Avatar
Still not chambered right for that kind of motor. Completely different exhaust flow properties. It'll work, I just think it won't sound too hot. I promise you it won't sound like it did on the pony.
Old Nov 25, 2012 | 07:48 AM
EsotericImage's Avatar
Retired Moderator
Still not chambered right for that kind of motor. Completely different exhaust flow properties. It'll work, I just think it won't sound too hot. I promise you it won't sound like it did on the pony unless you get a set of non vtec cams with a nice LSA.
Fixed
I mean, its not a straight thru muffler. Use a 18" or 20" resonator inline and you should be fine.
If you want to use a piping kit, these are great and best prices ive seen
http://www.vrsexhaust.com/TUBING_KIT.../honda_tk.html
Old Nov 25, 2012 | 07:53 AM
jbpnoman's Avatar
Still won't sound the same, getting closer though
Old Nov 25, 2012 | 08:33 AM
gsrturbo-ek's Avatar
yes can be used and will sound not bad
Old Nov 25, 2012 | 08:39 AM
redtherocket's Avatar
Should sound good if you can get the offset to work.
The thing with oval body magnaflow mufflers is that when you get a 2-1/4" in/out, its actually a 2-1/2" inside.
A shop I've gotten a few systems done at just orders 2-1/4" ovals because you can lop off the inlets and its 2-1-1/2..
At some point or another with a 2-1/2" muffler, there is the possibility of drone since the pulses will be spilling out at certain points....
But it shouldn't be to bad..
Just don't make your whole system 2-1/2"...lol
That would be bad.
Old Nov 25, 2012 | 08:41 AM
gzes's Avatar
Do its something not many people do and you cant knock it til u try it n hell u already have it so go nuts
Old Nov 25, 2012 | 08:52 AM
That would be bad.
How would that be bad? I suppose my knowledge of exhaust is limited here. I just don't want a a 3" tip though I have one tip from the Cobra still intact.
Old Nov 25, 2012 | 09:56 AM
Reason being is that the exhaust gas will expand and you will lose velocity.
When the correct size tubing is used, it will keep the gas compressed, allowing it to flow more efficiently..
If your hoping to gain power by adding one of these mufflers, your wasting your time..
But it should produce a nice sound...
If its to loud, get a longer resonator.
Old Nov 25, 2012 | 10:16 AM
Well the collector on the header is 2 1/2" so it won't be getting any larger because the mufflers are 2 1/2" also. So are you saying I should reduce size from the collector out to the mufflers?
Old Nov 25, 2012 | 10:49 AM
I'm not saying what to do whatsoever...
This is a very controversial topic and a lot of people don't know what they are talking about...
IMO though, 2-1/2" is kind of big for a D series..
A mandrel bent 2-1/4" would be more than sufficient..
My 4.6 Ford has true dual 2-1/4"... so that would be a 2.3 L on one bank..
Smooth bends though
Old Nov 25, 2012 | 12:08 PM
Smooth bends though
Oh this is going to be for a B20 engine in my Civic...man I was slacking on the info in my post
Old Nov 25, 2012 | 12:19 PM
I still think its a tad large...
What kind of header?
Are you installing a turbo?
Old Nov 25, 2012 | 12:53 PM
RMF standard tube. Funny thing is a lot of people here would say it's too small but I'm with you I kind of wondered if it wasn't too big also even though it's claimed to be for 1.6-1.9l and not the B20.
Oh it's n/a
https://honda-tech.com/forums/performance-45/plm-b-series-header-megasale-hytech-rmf-sp-toda-v2-%2Afree-shipping%2A-3015821/
Old Nov 25, 2012 | 12:54 PM
grumblemarc's Avatar
The Grumpiest
I'm wondering how many people need to tell you it's too large before you start listening?
If you're going to use one then run it over to a muffler shop.
