Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic LX 2-door coupe. Headlights quit working.
Old Nov 24, 2012 | 08:02 AM
quires_alita's Avatar
Icon2 Honda Civic LX 2-door coupe. Headlights quit working.
What are the causes of BOTH the low beams) to not work at the same time?
Old Nov 24, 2012 | 11:25 AM
lazlong's Avatar
Default Re: Honda Civic LX 2-door coupe
Check to see if both bulbs are good. You'd be surprised how often both go out. If they're both good, check for power to the bulbs. If no power, see if the relay is bad. If the relay is good, check for power to the relay
Old Nov 27, 2012 | 09:29 AM
K24_Y61P's Avatar
Default Re: Honda Civic LX 2-door coupe. Headlights quit working.
I'm going to take a wild guess and say this...
Originally Posted by InanimateCarbonRod
If your car is a 2001 or 2002, it could have been part of a NHTSA recall where the light switch terminal overheated and killed your low beams. Check out NHTSA recall 04V086000.
Here's a link for the lazy: http://www-odi.nhtsa.dot.gov/c...n=YES
Text of the recall:
Report Date : May 4, 2007 at 10:32 PM
NHTSA Campaign ID number : 04V086000
Make / Models : Model/Build Years:
HONDA / CIVIC 2001-2002
HONDA / INSIGHT 2000-2002
Manufacturer : AMERICAN HONDA MOTOR CO.
NHTSA CAMPAIGN ID Number : 04V086000 Mfr's Report Date : FEB 24, 2004
Component: EXTERIOR LIGHTING:HEADLIGHTS
Potential Number Of Units Affected : 440000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE LOW-BEAM TERMINAL ON THE HEAD LIGHT WIRE HARNESS CAN OVERHEAT AND COULD CAUSE THE LOW BEAMS TO FAIL WITHOUT WARNING.
Consequence:
AN UNEXPECTED LOSS OF LOW BEAMS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE HEAD LIGHT SWITCH AND COUPLER FOR SIGNS OF HEAT DAMAGE. IF HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE SWITCH AND COUPLER. IF NO HEAT DAMAGE IS PRESENT, THE DEALER WILL REPLACE THE HEAD LIGHT SWITCH AND ONE MATING PIN IN THE COUPLER. OWNER NOTIFICATION BEGAN ON APRIL 5, 2004. OWNERS SHOULD CONTACT HONDA AT 1-800-999-1009.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
If you think this covers your car, take your car to a Honda dealer. If your car is covered under the recall, Honda will replace your headlight switch at no charge.
Sgalena
Honda CR-V & Element
Apr 8, 2018 01:50 AM
ek_george
Oct 2, 2017 07:29 PM
ex2peria
13
Dec 21, 2012 01:44 AM
hernandezmike1
11
Nov 17, 2010 07:12 PM
B_CRUZ!
Nov 6, 2002 11:46 AM
