HEADLIGHTS WONT TURN ON
2001 HONDA ACCORD COUPE 2.3 VTEC 5 SPEED PARKING LIGHTS TURN ON BUT THE HEADLIGHTS WONT REPLACED HEADLIGHT SWITCH BUT THAT DIDNT SOLVE THE PROBLEM ORIGINALLY IF I REMOVED THE RELAYS AND REPLACED THEM THEY WOULD TURN ON BUT NOW NOTHING WORKS
Check the grounding on the car, they should be little black wires on the side of. The car. If they are dirty or corroded, get sandpaper or scotchbright and clean them and reground them see if that works, if it doesn't. Check your fuses to your headlights, the fuse box should be located under your hood near the strut bar. Make sure are of the little metal pins are still connected. That should fix it, if it doesn't the last thing you could do is check the actual headlight harness and see if they are dirty or corroded (since both your lights are out I doubt this it, but you can try) for a more drastic measure you could take it to a mechnaic and have him check out the cars power wiring, maybe a wire that powers your headlight is shot and isn't giving off enough voltage to them
confuseid
Aug 5, 2007 11:53 AM
