1995 accord over heating problem
Old Nov 24, 2012 | 03:23 AM
robmarsh781's Avatar
Default 1995 accord over heating problem
hey everyone,
i have a 95 accord with the 2.2l 4cyl vtec. so far i've replaced the water pump, timing belt, thermostat and gasket, and the thermo switch on the thermostat housing. when my car is sitting the temperature gauge will all of a sudden spike up to the red. i've also noticed that my fan only comes on when the ignition is turned off. i dont think its my head gasket because my oil is still looking like oil and it was also checked with a tester. im running out of ideas and think this problem is also killing my fuel mileage. any other ideas on what the problem could be would help!
Old Nov 24, 2012 | 08:41 AM
jdowen2's Avatar
Default Re: 1995 accord over heating problem
Did you bleed the coolant system?
Old Nov 24, 2012 | 05:33 PM
choshonda's Avatar
random but how much did you spend on replacing all those parts?
Old Nov 25, 2012 | 10:11 AM
papa123's Avatar
I had similar problem but was able to rectify by getting a mishimoto rad, 19lb cap,silicone 3 ply hoses also try a michimoto 60 degree T-stat
Old Nov 25, 2012 | 10:26 AM
716pro's Avatar
Run the car with the rad cap off until all the bubbles come up. You will know when its time to put the cap back on.
Old Nov 26, 2012 | 10:19 PM
papa123's Avatar
another way to get all the air out of kooling system is a bleeder valve on top of T-Stat housing open slightly till you get a steady stream of antifreeze and no bubbles then close it's a bit messy but works! good luck. Later dude
Old Nov 26, 2012 | 11:19 PM
Jessaaaaay's Avatar
Does both of your fans work? One of the fans which turn on when car is turned off is normal. But what bout the fan by the driver side? Does it turn on?
cgeorge
Aug 3, 2015 08:44 AM
youdntcme
Jul 28, 2013 07:12 AM
shawn323
Jan 17, 2013 12:41 PM
lursan
Apr 28, 2004 11:38 AM
rob_honda
Apr 1, 2004 04:05 AM
