Clicking sound when turning with new axle
Old Nov 23, 2012 | 02:19 PM
94 IntegraLS's Avatar
Default Clicking sound when turning with new axle
I just replaced my axle and whenever I turn I still hear a clicking sound but its not as bad as it used to be. When I replaced the axle and when I was looking around for any other possible culprits I noticed that the tie rod end (or atleast thats what I think it is) has a torn boot. Its a piece thats connected to the tie rod which has a ball and then looks like its connected to the steering rack? I'll take a picture of it if needed but can that piece there still cause a clicking sound when turning?
Old Nov 23, 2012 | 03:09 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: Clicking sound when turning with new axle
Similar situation happened to me
I just replaced the replacement, issue went away
Old Nov 23, 2012 | 08:44 PM
jonyi27's Avatar
If you bought it from a auto store should have warranty get it replaced
Old Nov 23, 2012 | 09:46 PM
fcm's Avatar
fcm
Old Fart
I guess we are assuming it's a 94 LS?
What part, and who istalled it?
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Also MM&Y of car and is it auto or a 5 speed? 94
Old Nov 24, 2012 | 05:09 AM
fcluddington's Avatar
also might want to add if the car has been lowered and if it's passenger or drivers side.
Old Nov 24, 2012 | 07:50 AM
It's a 96 integra LS automatic. Car is bone stock. I only replaced the drivers side axle. During an inspection of that area I found the boot on part #1 was torn.
Old Nov 24, 2012 | 09:13 AM
fcm's Avatar
fcm
Old Fart
Part #1 is the "Rack End Set", there is no "boot", or are you talking about #14, "Tie Rod End Boot"? 94
Old Nov 24, 2012 | 10:30 AM
That boot covers the tie rod end where it connects to the steering rack. It covers the ball joint in that #1 assembly. Could that exposed joint make a knocking sound as well?
Old Nov 25, 2012 | 07:45 PM
B20ztek's Avatar
its not your tie-rod, its the axle. oem replacement axles suck horribly, your best bet is to get oem axles and rebuild them
Old Nov 26, 2012 | 03:07 PM
kchungb17a's Avatar
I'm inclined to agree. It is not uncommon to have a newly "remanned" axle click on turns. I personally have sworn off remanned axles and always replace the boots before the outer joint goes. If it's past that point, I recommend to replace just the joint with an OEM one. It's a hard sell though, since an OEM joint is about $250 and a remanned axle is $100.
Old Nov 26, 2012 | 03:27 PM
fcm's Avatar
fcm
Old Fart
Are you talking about #10, Tie Rod Dust Seal, if so I have to agree with the others, it is most likely the CV joint in the "new" axle, I know of nothing in the dust shield that would click, although still possible, it's more likely to be the axle for reasons stated.
A very good "aftermarket" axle is... http://www.raxles.com/ much better then OEM at half the price. 94
Old Nov 26, 2012 | 07:57 PM
kodylive's Avatar
The axle u had got could be bad or could be a bad wheel bearing in some cases i would check to make sure everything is in right and tight first
Posted from Honda-tech.com App for Android
SoFresh
Feb 15, 2008 09:43 PM
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
CRISIS
Apr 23, 2006 08:52 AM
95GSRTT
Aug 4, 2004 10:01 PM
GReddy SI
12
Dec 21, 2003 12:14 AM
