d16y8, dx 5speed cable trans and p28 ecu. dizzy wiring.
Old Nov 23, 2012 | 08:44 AM
civicpei's Avatar
Default d16y8, dx 5speed cable trans and p28 ecu. dizzy wiring.
Alright guru's of honda. I have been doing tons of research on the swap that I will be performing when i decide i'm not to lazy haha. Anywho here is the setup that i have collected over the past few months. Picked up a y8 from a 98 civic si, a dx transmission from an 89 hatch, and a p28 ecu from a civic eg. now my question is: If i am using the obd2 distributor and the original obd0 harness and I have a jumper harness for the ecu. Can I rewire the dizzy wiring to the obd0 plug that connects to the original harness.
Old Nov 23, 2012 | 09:25 AM
91legend's Avatar
Default Re: d16y8, dx 5speed cable trans and p28 ecu. dizzy wiring.
You HAVE TO HAVE a vtec dizzy. Unless you somehow managed to use an obd0 b16 dizzy(not capable.) then you're ok. They make a jumper harness for the dizzy as well.
Old Nov 23, 2012 | 10:13 AM
v4lu3s's Avatar
RTFM
It can be done. I just did it with an obd1 distributor. I put an obd1 plug on the engine harness but had to trim the wire connectors for them to fit in the new plug.
Posted from Honda-tech.com App for Android
Old Nov 23, 2012 | 10:40 AM
91legend's Avatar
Then why is it everywhere I have read, you need a vtec distributor?
Old Nov 23, 2012 | 11:00 AM
civicpei's Avatar
http://www.tamparacing.com/forums/ho...tec-dizzy.html
I have read on the differences between the vtec and non-vtec dizzy's. I will be using the obd2 dizzy (y8) but the question (if I am stating it wrong is): make an adapter to go from obd2 dizzy to my original obd0 harness. OR! could I potentially keep the engine harness the same and repin the dizzy to mate with my obd0 engine harness. Do they not have the same amount of wires .
Aka. obd0 plug on my obd2 dizzy. plug and play I would think. ??
Old Nov 23, 2012 | 11:34 AM
91legend's Avatar
As I said, they make a jumper harness for distributors as well if you don't wanna go the route of repinning.
Work smarter, not harder.
Old Nov 23, 2012 | 11:47 AM
v4lu3s's Avatar
RTFM
took me about 15 minutes to re-pin. most of that was spent slightly trimming the rubber grommets on each wire as they are larger on obd0 than the obd1 plug needed. probably going to be the same with the obd2 plug.
Old Nov 24, 2012 | 01:35 PM
Canadian_EF's Avatar
I have a y8 in my ef and I'll share my experience.
p28 is not proper for this. Get it chipped with the so called y8 basemap or use a z6 cam gear I've heard.
The ignition/distributor timing will always be off if you don't.
The obd1 distributor can be used but severe spark advance is required. Same issue with obd2 distributor unless you get a y8 basemap.
With that much advance, you'll blow your motor, it's just a matter of time.
I toasted my first y8 w/ stock p28 and obd2 y8 distributor...
My current one has a chipped obd1 ecu w/ y8 basemap. Y8 distributor. Perfect ignition timing.
Learn from my mistakes.
Ps. An si transmission makes a big difference.
Old Nov 25, 2012 | 09:25 AM
civicpei's Avatar
Good info, thanks. always something to be learned. As for the dx tranny. I chose to go with this one because I am not looking for a fast car, just a car that can get me through traffic. this is a daily driven car. plus I would have to source an si tranny here, which is about as hard as finding a sasquatch.
Old Nov 25, 2012 | 10:03 AM
the DX tranny will definitely help with MPG. I sort of wish I had put the DX tranny in my car since I'm sitting at around 3-3.5k at 110km/h sucking up gas.
I guess I'm lucky with my Si tranny w/ no grinds lol.
efboy33
May 13, 2010 09:07 AM
CivCruise
Sep 10, 2009 07:49 AM
ef602
Aug 5, 2009 08:46 PM
ensracer
Jul 7, 2005 02:05 AM
FAST AS
15
Dec 24, 2003 03:12 PM
