Remote start works, but no air/heater
I've installed a Clifford 50.7X (same as Python 574 and Viper 5704) a month ago and remote start works fine, except the HVAC doesn't work.
The radio works fine, and I thought the HVAC and radio shared the same accessory output(white/black on my 00 Civic).
I haven't had time to check my wiring at the moment, but anyone may have an idea of what's wrong?
Is it possible it's related to the ignition 2 wire (yellow)?
Thanks guys. Just to make sure, I would assume red/white would be to constant 12V and pink/white to yellow at iginiton?
H3/1 Pink - Ignition 1 Input/Output
H3/2 Red/White - Ignition 2/Flex Relay Input 87/+12V input
H3/3 Orange - Accessory Output
H3/4 Violet - Starter
H3/5 Red - Ignition 1 Input
H3/6 Pink/White - Ignition 2/Flex Relay Output
H3/7 Pink/Black - Flex Relay Input 87A key side of flex relay
H3/8 Red/Black - Accessory/Starter Input/+12V input
Yes, and should be "programed/wired" as an accessory, [hot in run but not start] you do not want the blower motor on when starter motor is cranking the engine. 94
Thanks, I found out I've hooked the red/white wire to ignition 2 and with no connection on pink/white. I just connect red/white to const. +12V and pink/white to yellow ign2, and it works great.
dafuzzbudd
Audio / Security / Video
13
Oct 4, 2008 03:52 PM
