Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
No Dash lights
Old Nov 22, 2012 | 09:17 AM
Tr4xX's Avatar
Default No Dash lights
Hello,
I just recently bought a 2008 Ridgeline and noticed the dash lights don't light up. It is the AC/Heater controls and buttons, the select, reset dome light and cargo buttons that don't light up either. I do get the two orange lights that come on when you push the defrost or recycle air buttons.
The Gauge cluster is fine and the headlight switch lights up, if I adjust the dimmer switch the gauge cluster brightness adjusts so I would assume its working I also checked the #4 fuse under the hood label "small lights" and it was fine.
I then thought well maybe they are all burnt out so I bought neo wedge led replacements and replaced them all and still not one of the buttons light up, at this point I am not sure what else to check. Has anyone experienced this problem or have any idea's?
I have replaced the factory stereo but I used a wiring harness that plugged into existing harness so I don't think I messed up anything there.
Thanks
Old Nov 23, 2012 | 01:47 PM
Tr4xX's Avatar
Default Re: No Dash lights
Just to follow up, it was the illumination / dimmer wire. The wiring harness diagram had both the orange and orange/white wires listed as illumination so I ended up wiring them both into the illumination wire for the headunit and thats where I went wrong.
Looking at the wires more closely one was labeled dimmer and one dash light illumination but was hard to see.
In the end I disconnected both as the headunit has a built in auto dimmer feature.
Something so frustrating yet so simple.
Integra4lyfe069
43
Oct 11, 2017 09:57 AM
OklahomaEg
Mar 6, 2013 09:31 AM
shoebox
Sep 28, 2012 04:39 AM
hondafreak2134
Oct 10, 2009 05:24 PM
